but man, can cause damage for battery or other components ? Like charge components, etc ?
No, as we have built Diablo's battery to not charge past 80%. This will increase the longevity of the battery.
The other components are fine and it's not something you need to worry about!
I got a Diablo from Amazon, and it was working ok for about a day but now the green light doesn't stay on and its unusable. I have it plugged via the USB cable direct to the mains plug. Have reheated cables, but when I switch it on the green light appears for a second or so then goes off and the unit is lifeless. Anything I can do? The small red light at the back of the unit is flashing.
/Update - I unplugged and replugged it all in again for the 6th time and now it appears to be staying on, for the time being at least.
The flashing red light indicates the battery has less than 10% charge left. Although you have it plugged in to the mains adapter it may be the case that the Diablo draws more power than the charger can feed it resulting in battery drain (esp. if using Turbo mode)?
If you experience the issue again it might be worth fully charging the Diablo whilst powered off and see if that helps. Takes approx. 6 hrs iirc.
Looks like folks here have you covered on what I was going to suggest @marcus2704 - keep us posted and let us know if you need anything else.
Hello
I am waiting for an used Diablo that will arrive in a few days, and I have a question :
I have a N6II with A02 module (dual AK4497ESQ with pure balanced line out).
What will give the best sound, connect with balanced line out and use Diablo only as amplifier, or connect with USB and use Diablo's Burr-Brown DAC ?
You are right !
So no question, I will connect by USB, and rather my phone...
Thank you for quick answer
Correct hope you enjoy it and look forward to your feedback once you get it!
