CH23
- Nov 24, 2012
the GTO filter is nearly 1:1 with how MQA soundsBut… can I use the mqa one with regular flac files without making than sound “off”?
For those who prefer a slightly warmer sound, give fw 7.2b a try. I have upgraded back and forth most firmwares available for the diablo.My Diablo still has the stock firmware on (no idea which one). Is there any specific firmware that is really worth loading?
I normally prefer a slightly warmer sound...
Limited by memory..you have to catch up on the threads.If we want to change the signature then doing it via firmware change is messy, inconvenient and risk of wrecking something. IFi should have added buttons or some other on device method to switch.
Makes me think it hasn’t been thought through
that's a bit silly to be honest. I think most people would never even update from the factory firmware, let alone 'roll' firmware.If we want to change the signature then doing it via firmware change is messy, inconvenient and risk of wrecking something. IFi should have added buttons or some other on device method to switch.
Me included.that's a bit silly to be honest. I think most people would never even update from the factory firmware, let alone 'roll' firmware.
@Soundizer
Covered already but....
The Diablo has an RRP of £899 in the UK (but can be found for £809 new if you shop around). That figure includes VAT at 20%. So the cost before tax is £750.
At today's exchange rates that equates to approx. $980 USD. So $20 USD cheaper than the US RRP, which as mentioned does NOT include tax.
TL;DR the UK isn't getting screwed by iFi when it comes to pricing.
Nothing is wrong here in general. Normally you can use any DAC with active speakers in case the DAC has a pre-amp mode or the speakers have a volume control.
BTW,
And you can try IEM if you want. Good luck)
P.S. @iFi audio Diablo needs a pre-amp mode
Depends on the person. Some can't tell a difference but for critical listening GTO on regular pcm is better. Regular pcm on mqa firmware is good as well.
Upgrading from Idsd signature (xmos 208), to my ears:
Fw 7.3 (diablo) = fw 5.3 (signature)
Fw 7.2 (d)= fw7.3 (d) = fw 5.3 (s)
Fw 7.2c (d) = fw7.3c (d) = fw5.3c (s)
Fw 7.4 (d) = fw 7.4 (s)
Fw 7.2b (d)= fw 5.2 (s), which sounds most analogous for PCM and DSD including the use case of upsampling pcm to dsd (my own and subjective opinions).
It is interesting that fw7.2b of the signature can be used smoothly for the diablo.
For those who prefer gto/MQA/PS4/5 compatible features, this may not make sense though.
Me included.
I have no idea which firmware is installed and have absolutely no intention to download another.
Firmware rolling... man...
Diablo is more resolving and has more extension top and bottom so signal chain issues will show itself more on the Diablo than the Gryphon. Takes a week to break in anyways. If you're doing USB, idefender + USB optical cable can help.Hi all. I just got my Diablo in the mail. Detail, transients, impact, and dynamics are really impressive and the power output is crazy. I'm barely at 11 o'clock with Aeon Flow headphones on eco mode and it's pushing 70 dB.
I'm noting this is much brighter than I was anticipating, almost like THX789 bright. Cymbals sound really crunchy/splashy.
This is very fatiguing even at low volume level. I can't really go lower as I get channel imbalance. I'll see how they do with Verite Closed, but I got this device to use with Aeons at work.
Do the treble and upper mids calm down with extended use or is this amp device very bright?
In contrast the Gryphon is much less sharp in the treble despite being very detailed.
I've been listening for about 2 hours. Will have to take a break soon, this is really fatiguing. I may be sensitive to certain amps. I had to sell the THX789 due to being too fatiguing in the treble but that's the only amp I have heard that has ever caused me any issues.Are those immediate impressions after plugging in or did you give it some time to warm up? What songs you listening to? @tcellguy
The amp is a departure from the warmer iFi house sound. The design is closer to that of THX amps so youre hearing that right. I personally don't find it too bright but definitely more "neutral" compared to say Micro IDSD or Zen amps.
Maybe it would benefit from some "burn in" but I don't recall mine sounding all that different from when I bought over a year ago now. Its actually paired quite nicely with all the headphones I've had. Currently listening to my Diana Phi with the Diablo in bed and it sounds great from jazz to house. Either way I hope you end liking it more.
Something still sounds very off about cymbals, like distortion or something. I've tried a few of the 7.4 firmwares, maybe non GTO is a bit smoother.
Genres: lol I listen to metal. The impact from the Diablo is perfect really, almost class A sounding. I just switched over to some electronic and Fleetwood Mac and that was less fatiguing. I'm going to give some classical a try.
