Trance_Gott
I would go from my Shanling M8.I did with Susvara. Low gain 4.4 is best for me. Good sub bass extension and quantity. As long as u have a good upstream signal chain.
Has someone test Susvara or 1266 TC?
gone and ordered myself the FOCAL Clear MG Pro , should be here tomorrow
Do you guys know what is the voltage on the 4.4 mm rear analog output? 6V ?
"iDSD Diablo's 4.4mm socket outputs 2 (SE) and 4V (Balanced), while its output impedance is 150 ohms per phase. Thanks!"@iFi audio posted the specs a little while back : Here
You are correct. I would assume that the 2V SE figured referred to would be if the Diablo's balanced output was used in conjuction with a stereo XLR to RCA type adapter to feed an SE headphone amp say, which I believe would result in a halving of the voltage? I could be wrong though."iDSD Diablo's 4.4mm socket outputs 2 (SE) and 4V (Balanced), while its output impedance is 150 ohms per phase. Thanks!"
There is no SE output on Diablo (in a DAC mode)
You misunderstood. What is 899 GBP in USD?Wherever you got your information from, you have been misinformed.
As mentioned by other people the 999usd in USA does not include tax.You misunderstood. What is 899 GBP in USD?
