Hello I am new here and posting the following message to get some help.
I am experiencing allot of background hiss on my new ifi phantom amp.
Here is my current and NEW setup
- Computer to ifi dac via usb
Ifi dac to ifi phantom via rca
Ifi phantom to either iem and headphone via a unbalance output
- 64 audio 12t iem
- theiaudio origins iem
- hifiman arya stealth
- hifiman he1000
- please note only thing new in this setup chain is the ifi phantom, this issue did not exist in teh past in any of the amps (previous amps included smsl, ifi can 2, element audio, schiit)
- My old set up i.e. prior to receiving ifi phantom
Ifi dac to ifi can 2 via rca
Ifi can 2 to either iem and headphone via a unbalance output
- 64 audio 12t
- theiaudio origins
- hifiman he1000
Things I observed
- Hiss sounds like constant background electrical hiss grain type noise
- Hiss present at all volumes on both headphones and iems in all of the above stated volumes
- Hiss same amplitude (level of loudness) no matter changing the volume dial i,e, if i increase the volume the hiss amount does not change
- Iems produce a louder hiss compared to headphones, likely because they are more sensitive
iem match feature - Specifically for iems I tried iem match feature and With iem match feature the loudness of the hiss became lower but present all the time. Again both headphones and iems
Settings at the phantom amp
- 0 gain
- ESL off
- tested on unbalanced 3.5 output and both right and left 6.35 output - same issue replicated
Things I have tried to troubleshoot
The esl is off, has been off the whole time I was trouble shooting.
I am currently plugged into number 20, but I am able to replicate the issue 12 (via 6.3 adapter plugged into the right channel)
- Changed the USB cable of dac - no change in sound noted
- unplugged all other usb devices from computer even mouse and keyboard - no change in sound noted
- Changed ifi dac to element audio dac- no change in sound noted
- Change source from computer to laptop - no change in sound noted
- Next
Changed the RCA cables from DAC to amp - no change in sound noted
- Next
I directly plugged the phantom amp to the wall socket, no power or extension cords - no change in sound noted
- I tried iem match feature and With iem match feature the loudness of the hiss became lower but present all the time. Again both headphones and iems
Questions.
1. What is going on? I am not an engineer, just a simple consumer with a simple Understanding that this high end expensive amp should not be producing this result.
2. I have the ifi can 2, this was never a problem with that amp and it's a 300$ amp. in addition pulled out an old smsl and schiit amp , no background hiss issue with above mentioned iems, seriously curious and want to know why are these amps not producing these results what is about the design or components in these amps that is not present in ifi phantom.
thank you in advance
