e-dub
Let me know if you don't hear from them in 24 hrs or so, please. I will look and see if you sent me a PM with your support ticket number...
Cheers!!
Sounds good. Thank you!
Cheers!!
I wonder if it is something with the Pod or with the case possibly just not charging...Yes, if it helps mine doesn't flash green or red. It just stays green. Very odd.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Try this, disconnect the earloop and just hold the Right Pod into the left slot, (You have to hold pressure on it) and see if the light turns red. (Charging state)
Cheers!!
Hmm... Quite concerning...
So the light stays green no matter what right? I wonder if trying that reset I posted might jar it back.Yeah, I absolutely love my Go Pod and it's been my daily driver for a year.
I only say that because there is battery life left in it or there would be no light at all.
Let me know!
Cheers!!
I thought - but I could be wrong - that this was addressed in an earlier firmware update…According to the notes at the bottom of page 5 of this document, LDAC at 990kbps is MONO. I didn’t realize that.
https://ifi-audio.com/wp-content/uploads/2023/06/GO-pod-Manual_Ver0.19.pdf-non-bundle.pdf
That was the case in older firmware (pre- v1.49, IIRC), now it is stereo.According to the notes at the bottom of page 5 of this document, LDAC at 990kbps is MONO. I didn’t realize that.
Greetings,
Thank you all for sharing valuable information about Go Pod.
Sound quality is really phenomenal and render justice to my Audeze iem. Personally, I like physical button similar to Fiio utws5, Xelento wireless 1st gen, Westone W80-3 instead of touch control as I always accidentally touch it (even on the edges) and launch some undesirable command while mount/unmount from my ears.
One thing I find very annoying is every time I take the pod out, adjust the volume to my liking, which I prefer to have some level indicator by the way (Fiio control app), put it back to the case. Next time I take them out, I have to readjust the volume level blindly all over again. I wonder if anyone else experience this.
1.52 Firmware
Sony Xperia 1 V
Audeze
First of all, I strongly suggest you to update to the latest Firmware, which is v1.54.
Please, make sure you follow the instructions on the iFi Support Hub to the tee, so that you will update successfully.
What happened with your unit? Have you been asked to send it back to the dealer for a replacement or for further examination?@ecouteurifi , I do not recommend updating the firmware: I followed the instructions perfectly and ended up having the process fail on me at the very end, leaving my set useless, for the time being.
Here's the chronology:What happened with your unit? Have you been asked to send it back to the dealer for a replacement or for further examination?
In any case, I think that iFi Audio (@iFi audio ) should definitely do something about this, fast, because it is preposterous that the users will be made scared to update the firmware due to potential failure...
