Apr 27, 2023 at 9:48 AM Post #1,471 of 1,663
The go blue does a decent job driving the HD820. I was actually shocked at the power of this little beast.
May 21, 2023 at 7:48 AM Post #1,476 of 1,663
hi there, just bought the Go Blu week ago, wanted to ask what version is the latest firmware? my out of the box Go Blu seems running more up to date version than the one on the firmware download page
If I may ask, which one is installed on your device?
May 21, 2023 at 8:45 PM Post #1,477 of 1,663
Screenshot_2023-05-22-07-44-19-736_com.qualcomm.qti.gaiaclient.jpgthis one
May 25, 2023 at 9:02 AM Post #1,480 of 1,663
Am I crazy or does the iFi-Gaia app not show up in the Google Play store? I'm in North America on a Pixel 6 if that matters, and all I get is the Stream iFi app (even if I scan the QR code for Gaia).
Meanwhile it shows up on iPhone just as expected.
Yes, it shows for me on my iPhone as well, I do not have an Android phone. Can you go here and see if you can get it from this link?
https://ifi-audio.com/support/download-hub/
Bottom of the GO BLU page
Cheers!!
May 25, 2023 at 11:27 AM Post #1,481 of 1,663
Thanks, I hadn't found that. It leads to a ZIP download which for some reason my Pixel did not initially want to open. Tried a different file manager and that worked, got the APK installed just fine.
Still weird that it isn't available via the regular Play Store method, but this works.
May 25, 2023 at 11:34 AM Post #1,482 of 1,663
Glad you got it! I will also report the app not being on the play store, if I remember when I used it on an Android tablet it came up iFi-GAIA so I don't know if that makes a difference.
But, I will look into it regardless! Thank you for pointing it out.
Cheers!!
May 29, 2023 at 8:30 PM Post #1,483 of 1,663
Hello all!
I’m running into an issue where, when the iFi Go Blu is connected via a short camera adapter Lightning-to-USB C cable to my iPhone Pro 14, it drops out every 10–15 seconds or when I switch to a different app (no video or sound in the different app). Bluetooth works fine, and it works fine wired to a MacBook Pro 2021. I updated the firmware but the problem persists.
Any advice? This is a new problem since the GO Blu has worked wired to my iPhone before (and yeah, I disconnected Bluetooth on the phone prior to connecting via cable).
Thanks!
May 30, 2023 at 7:37 AM Post #1,484 of 1,663
Hello all!
Thanks!
Have you tried cleaning the IPhone port and tried a different cable to make sure it’s the GOBlue?
May 30, 2023 at 5:36 PM Post #1,485 of 1,663
