As soon as I saw that ddHifi was launching a new lightning cable, I was thinking to give it a try. Today I am happy to announce that the new MFi07S Lightning cable works fine with the iFi Go Bar (non-gold version) with an iPhone 14 Pro Max.
I am currently using the firmware version 2.20a and so far, the following cables are working fine with my iPhone 14 Pro Max:
- HiBy Lightning cable
- Fiio LT-LT1
- ddHifi MFi07S
And the cables that I own and do not work with the iFi Go Bar:
Regarding the MFi07S cable, it is quite expensive, but the build quality is exceptionally good. The connectors feel rock solid, and the actual cable/wire feels as flexible as the stock iFi cable but has an outer insulation layer of PVC that makes it more durable compared to the stock one:
If you are curious about the technical specs of this cable, check the product page
here.
