iFi audio GO Bar - The Best Pocketable HiFi System, Bar None!
Sep 10, 2022 at 7:59 AM Post #527 of 1,199
Hello all! I thought I'd give a quick introduction. I'm Rowan and I work for iFi audio. I will be around and assisting our official account as my role here on Head-fi.org. Please feel free to tag me in a post if you ever need anything. Thanks :)
Do you think ifI would ever consider re-releasing a new inventory of the Gold bar, given how popular it seems to be and the general consensus that it sounds better than the regular "go bar" version?
Sep 10, 2022 at 5:35 PM Post #528 of 1,199
Hi Guys,
Today we are taking a look at what is probably the smallest piece of gear I have ever reviewed, the iFi Audio GObar. The GObar is what typically gets called a USB Dongle DAC/Amp nowadays. I’ve spent time with a few of these types of devices over the years, but it seems that in the last two years or so the availability of options on the market has absolutely exploded. It seems to be the case nowadays, especially from so called “Chi-Fi” companies, that they all have at least one product of this type in their line up. This type of product and its form factor does seem to have advanced rapidly in its capabilities, the GObar being one example of this. iFi is a fairly consistent example of pushing the amount of features available in a device in its given market space and form factor, and the GObar does seem to continue this trend.
I remember back in a 2015 I bought an LH Labs Geek Out V2, which was a disaster in terms of usability and design, but sounded great for its size and the market at that time. I never would have expected devices of this type to have come so far in such a short period of time, but compared to that GOV2, and the original AudioQuest Dragonfly, the GOBar is a revelation. However, it has very stiff competition from the vast array of similar devices on the market, so let’s check out how it sounds and performs.
In terms of overall tonal balance, the GObar reminds me of the time I spent with the HipDacV2 from iFi. Its has that slight warmth to its mid range, but does seem slightly different from the traditional iFi “house sound” I have come to know very well. It’s a bit brighter and sharper than I am used to from iFi. This does work well with some headphones, but if you are perhaps using a bright pair of IEM’s for example, it may not be the best choice. The bass seems mostly neutral to me, not being bloated and sluggish in any way, but also not lean or cold. The mids, especially the lower mids, are again slightly warmer than neutral. The highs are slightly tipped up as I mentioned, but this does help things sound a bit lively and helps details in the top end come across easily.
In terms of things like detail and technical performance, it’s pretty remarkable compared to the dongle market in 2015. The GObar is genuinely an engaging device to listen with. Is it comparable to the Pro iDSD from iFi? No, not really, and yet, you have to keep in mind the size and MSRP of this little device whilst you are using it. I was listening with my T+A Solitaire P at one point, and really didn’t find myself wanting for much. I was just enjoying my tunes, and wasn’t thinking I was missing out on anything or being annoyed by something in particular. The overall detail levels for the price range are totally in line with what they should be, and the sound staging etc…are slightly wider than neutral.
In terms of filter options, the GObar has 4. Bit perfect, Standard, Minimum Phase, and the same GTO filter that is featured on the Pro iDSD. I ended up preferring the GTO filter, similar to my time with the Pro iDSD. My second favourite was the “Standard” filter. Also in keeping with iFi’s other equipment, the GObar includes the XBass+ and XSpace options. I really enjoy the XBass+ with most headphones, but do find the Xspace works better with some recordings than others. Thankfully, both options are easily switched on and off with a single button on the side of the unit, so you can try them out and see what works best for you and your ears.
Also included is iFi’s “IEMatch” technology for use with sensitive IEM’s. This is a very handy option if you are experiencing a bit hiss with your easy to drive IEMs. I ended up not needing it personally (my IEMs are not sensitive at all,) but it is there should you have a sensitive pair.
There is only one input into the GObar and that is done via USB-C. I am so happy iFi went with USB-C and not with Micro-USB. USB-C is a better, more reliable, and overall better connector type with better longevity. In terms of output there is a 4.4mm Pentaconn fully balanced output, and right beside it iFi 3.5mm “S-Balanced” connector, which aims to bring the benefits of a balanced circuit to single ended devices. The GObar does a rock solid 475mw into 32 ohms from the balanced output, and 300mw from the SE output. This is somewhat higher than the power output of similar “Chi-Fi” devices on the market. One thing I would have liked to see on the GOBar is slightly easier to read lettering on its rear. I found myself having to hold it in the light at a certain angle to read what options I had on or off. It’s not a big thing, and I suppose it would spoil the “clean” look of the GObar, but it would make it slightly easier to use.
Now, this is the difficult question. The GObar retails at $329USD. This is higher than the other aforementioned “Chi-Fi” dongle options on the market. If you are in the market for a USB Dongle DAC/Amp and it is simply going to be for totally casual listening, or maybe to serve as a backup for your backup of your desktop setup, then I would seek out one of the cheaper “Chi-Fi” options. A lot of those will do a decent enough job and have enough power for IEMs and easier to drive headphones etc….BUT, the GObar from iFi would 100% be my recommendation for other uses. Perhaps this is going to be your only DAC/Amp, if you are a beginner or need something small and transportable. Maybe you have decently difficult headphones to power as well as IEMs, for those people, I would unquestionably recommend the GOBar. The extra $100 or so USD is worth it in those cases. As with everything in this life, it all depends on you and your own personal use case.
The iFi GOBar, whilst being slightly more expensive than its competition, does bring some new features to the USB Dongle DAC/Amp market, as well as higher power output. It seems to have a lot of the features I have enjoyed about iFi Audio gear, yet it is this tiny little portable dongle. The amount of sound quality, and features in such a tiny package is pretty remarkable. If the GOBar fits your use case, I wouldn’t hesitate to recommend it. If you happen to just need a back up of your backup gear, there are other cheaper options on the market that might suit you better, but if you need a USB Dongle that is more “all out” in its capabilities, then the GOBar is the way to go.
Sep 12, 2022 at 2:09 AM Post #529 of 1,199
Got the same problem as some of you with connecting to Iphone 12 pro max. Opened a ticket at IFI and let´s see what happens. Did they solve it for the rest of you with the same problem?
Any luck? They manage to offer a fix?
Sep 17, 2022 at 12:08 AM Post #530 of 1,199
I'm pretty sure (about 90%) that this is your problem: By default, all Tidal apps perform the first MQA unfold in software. However, the Tidal Windows PC app allows you to select "Passthrough MQA," which disables software decoding by the Tidal app and sends the stream directly to the Go bar without performing the first unfold. (I assume this option is enabled on your PC app since you are getting a green or blue indicator.) The Go bar's MQA decoder will then perform all unfolds, fully decode the stream and the green or blue MQA indicator will light. However, for some inexplicable (or maybe insane) reason, the Windows app is the only Tidal app that provides this option. You simply cannot disable software decoding by the Tidal Android or Apple apps (I've tried it on my Android phone and tablet and an Apple iPad); those apps will always perform the first MQA unfold in software and send the stream to the DAC. In this case, the Go bar's decoder recognizes that it is receiving an MQA stream but, since the first unfold has already been performed by the app, the decoder cannot authenticate the stream and therefore always lights the magenta indicator. (I apologize if any of this is technically incorrect; I'm no MQA maven. But it's broadly correct.) Supposedly, sound quality is the same either way.
The only way to light the Go bar's blue or green MQA indicator when using the the Tidal Android app is to play Tidal through a third party app like USB Audio Player Pro, which does provide the option to disable software decoding if connected to a DAC with an MQA decoder. I use this app, with software decoding disabled, on my Android phone and tablet and the green or blue indicator on the Go bar does properly light when playing an MQA track.
Honestly, I'm not sure if it's Tidals problem or iFi's.. Even when passthru MQA is turned off the GO Bar still lights up Blue or Green. If Tidal does the first unfold, my Go Bar's light should be purple. No matter what. I think FW1.7 messed the device up. It doesn't even work with my 12 Pro Max. I just realised this problem was first reported late June. It's mid Sept now and now news of a fix. I'm hoping I can get a refund from my local dealer or an iFi product that actually works.
Sep 19, 2022 at 12:40 PM Post #532 of 1,199
Hi. Has anybody found a lightning to USB-C cable that works?
DDhifi make a cable that passes audio from lightning to USB C This one here or if you have a dongle dac that relies on the internal iPhone/iPad battery for power then This one here will do.
Or you could buy the apple camera connection kit and use any suitable cable than can handle data transfer
Sep 19, 2022 at 1:47 PM Post #533 of 1,199
THX :wink:
My Topping G5 has batterie and the iFi GoBar is without batterie. But both of them are working with the cable that came with the GoBar:
Sep 27, 2022 at 5:25 PM Post #536 of 1,199
I'm getting uber antsy for a case to put my gold bar which will allow me to use it too. After looking at the dimensions, I have come down to two ideas:
- Cut a hole in the leather case that comes with the Go bar which would allow me to use the USB-C port on the device while it is in the case
- Try a case built for something else
As an owner of the Cayin RU6 in the past, has anyone tried the leather case that comes with it on the go bar? They seem to be very similar in size.
Sep 27, 2022 at 11:54 PM Post #537 of 1,199
If anyone here is still looking for a good Lightning to Type C OTG cable, check out OE Audio's OTG cable: OEOTG Digital Cable – OEAudio
Normally the manufacturers don't mention the current output issue with iOS devices but this one does so yeah, it works with the Gold Bar and it looks nice :)
I see another brand: Audirect scheduled to release their own Lightning to Type C cable (named T-1) with an emphasis on current output as well, hopefully that one is another good cable to look out for.
Sep 28, 2022 at 12:37 AM Post #538 of 1,199
What would be the benefit of:
"Most of the Lightning OTG cables, which have output of 3.3V 100mA cannot fulfil the need for portable DACs. We redesigned the circuit, which the OEOTG cable can achieve a 5V 200mA output."
Would it improve SQ?
Thanks
Torben
Sep 28, 2022 at 12:51 AM Post #539 of 1,199
Thanks
Torben
When you use dongles with an iPhone and low impedance, low efficiency headphones, the dongle may need more current than the 100mA supplied by most lightning OTG cables. In that case the playback will start cutting out and you will need to decrease the volume. A cable that supports 200mA would theoretically let you crank up the volume all the way up. I am not sure though whether this limitation has to do with the cable or iOS/the port itself.
Sep 28, 2022 at 1:01 AM Post #540 of 1,199
Thanks
Torben
I would say it improves stability. I have a few lightning to type c cables that works with the Gold Bar but in certain scenarios I observe the connection cutting in and out.
For me the easiest way to test is to enable IEMATCH on the 4.4mm output and crank up the volume on the Gold Bar. Usually this causes problems for me and the connection starts to randomly break with certain cables.
