AudioSpender
- Apr 5, 2014
I will post a video by this weekend. Sorry it is taking long I am very busy at work.
Wow I don’t I feel dumb I tried to use it originally and thought it doesn't fitTo get the input back, please use the 'angled fork' connector that clamps onto the DC plug from the DC power supply.
I know they use the same graph style in other products I thought I remember them explaining it. Also could the fact that the Entec wideband noise analyzer being a simple one might pick up more noise for some reason@iFi audio can you please refute what @AudioSpender said with actual measurements graph of AC iPurifier in action instead of a drawn one?
It seems strange the result he is measuring with a simple Entec wideband noise analyzer.
Thanks!
Hi, bought two of them and they really work.Was surprised by the better definition.
Short question @iFi audio
So when I put the AC iPurifier in a wall socket and the polarity light got red, I just turned the iPurifier around and both light went green.
Is this what you are supposed to do when the phase light goes red?
Please note, I did not change anything else, I only turned the iPurifier by 180 degrees.
Sure. I bought it here http://amzn.to/2I14qC7 via amazon. hifimedia is the company doing the fullfillment.Where did you buy them from if I may ask?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Hi Richter Di
Leds are green meaning it is ok for both.
Best wishes
iFi audio team
Polarity check verifies if the phase and neutral are connected correctly in the receptacle, so that they are also sent in the correct wires to the connected equipment. That is because gear usually work better when they are connected correctly.
Many AC plugs around the world have only 1 way of connecting, example the typical US 2 blades + 1 round ground plug. So the check makes sense to verify if the installation was done correctly.
But some countries have plugs which are reversible, like only 2 round pins, so reversing them fixes the polarity.
Sorry, I still do not get it. When I put the iFi in an the polarity LED gets red what does it exactly mean?
And why is it turning green when I turn the iPurifier around?
