Up to this point, Audio Technica CK10s were the best fit I could find for my somewhat small ears. Can you guys tell me if the current Shure IEM line are all the same size, and if so, how big/small they are to other IEMs at the moment? I may just grab the 215s from Amazon to check fit, then exchange for a higher priced Shure if they all will fit the same. I'm also going to try the higher-end of the Heir universal line, hoping they're small enough to fit me. Any comments on this?
IEMs for small, fussy ears that sound great
Mimouille
The Heir 5.0 are pretty small for a 5 driver. Among the smallest I have tried are the AKG K3003 and maybe the Senn IE800.
tomscy2000
Try the JAYS Q-Jays or the ACS T15 (aka Crescendo Hearing / Dynamic Ear Company DS-11)
Just ordered the TDK BA200 since they aren't that expensive and can be returned easily to Amazon. Also have the Heir 5.0 ordered, and Heir is sending along the 4.ai to me to try on loan, as well. If the Heir fit me well, which I'm crossing my fingers they do, I'll choose between the 4.ai and 5.0. Will be using them with the HRT Microstreamer and a Headstage Arrow 4G.
jonyoo
- Apr 5, 2013
A friend of mine got the Jabra Vox. They are really tiny lol.
- Aug 30, 2012
Has everybody forgotten about klipsch x10?
ryanjsoo
Reviewer for The Headphone List
ryanjsoo's Reviews
^+1 for klipsch x10, easily sleep with them in, so small and so comfortable, sound packs a punch too, just highs are a tad rolled off.
tomscy2000
In terms of tiny-ness, these two are definitely the two smallest. They make the CK10 look like a giant. The X10 doesn't come close.
Mimouille
The Hisoundaudio BA100 is pretty small too.
Thanks for those suggestions. I pulled the trigger on TDK BA200's from Amazon, and they'll be here tomorrow. If they don't fit it's an easy return. I also ordered Heir 5.0 because I still want great sound. If those don't fit, I guess they'll be up for sale here at a small discount
zyd1996
- Oct 1, 2013
Kplish x10 is the smallest iem in the world.
I probably should've clarified. Smallest IEM that's as small or smaller than, and sounds as good or better than, the AT CK10? lol
Sylaw
- Nov 1, 2011
as far as I knw CK10's and the X10i's are the smallest IEM's that I have ever used
so they are the once
zyd1996
- Oct 1, 2013
So would you please tell me what is the smallest iem in the world?
