Surf Monkey
- Nov 7, 2011
Dropping a couple hundred here and there can easily add up to one $1000 set that blows all the cheaper ones you were chasing out of the water. Sometimes it makes sense to save up and go big.
I’ve done both. My “expensive” IEM from nearly a decade ago now is the CA Andromeda. I’m still just as satisfied with it as the day it came out of the box. But I also have plenty of mid and lower tier IEMS. Each has its own sound. Each is strong in one way or another. There’s merit to saving up for a mid or upper tier set and there’s merit to trawling the entry and mid tier for phones that punch way above their weight. Because they are out there.
Advice wise, regardless of how much you want to spend, even if you’re in the sub $100 range I agree with everyone who has suggested resisting the hype cycle. It’s like a Ferris Wheel. It goes around and around without really going anywhere. You can jump on or off at any time with basically the same result. Instead it’s advisable to sit on the sidelines until people have reviewed a set, until a few trusted members own one and can comment on them, and if possible until you can personally audition them.
And of course it goes without saying that all of us achieve this goal to varying degrees of success and failure. No approach to this hobby is correct and none is incorrect.
