After owning an HP8 MkII SE for 12 months - with lots of use out of it - in a vinyl only rig into HD800S, I decided to try some new tubes.
My SE edition from stock came with Shuguang Black Treasure CV181s and an EH 12AX7 gold pin.
The Shuguangs never did seat very firmly, I have to say.
On considering new tubes, I telephoned Icon Audio and ended up speaking with David Shaw.
According to Mr Shaw, the circuit design of the HP8 has a wide tolerance for either less-than-perfect matching of the power tubes or degradation over time of tube performance.
Moreover, Mr Shaw made the point that the circuit as a whole - rather than simply the tube component - is responsible for the tonality, dynamics, and so forth of the amplifier. He even stated - and I hope I am not being indiscreet - that he "cannot hear differences" when tube rolling the HP8... Quite an admission, given that the SE version is sold as an upgrade in terms of tubes and capacitors (perhaps this is understood as capacitors influencing tonality, tubes only as a matter of mechanical integrity or longevity?)
Members here on Head-Fi - conversely - claim that tube rolling is VERY AUDIBLE in the HP8... What are we to make of this difference of opinion between designer and end user?
Well, today I rolled in Psvane CV181-T MKII (aka. 6SN7 GT) power tubes (the ones with the grey coating) and a Genelex Gold Lion 12AX7.
(Taken together, quite bit more expensive over the stock tubes with the SE version as shipped.)
What a disappointment! My HP8 is now rendered much, much worse!
Regardless of what Mr Shaw claims - and I mean this with all due respect - the HP8 is, very obviously, affected by tube rolling: noise floor is appears identical, as does the excellent channel matching (recall, I'm running a vinyl only rig). However, frequency response is HUGELY altered. To offer an example, the MoFi 45RPM "Brothers In Arms" is famously punchy in the low frequencies (to the extent that some turntable/cartridges had tracking issues on side 2). The HD800S are known for being bass shy. Yet with the stock Shuguang/EH tubes, my HD800S would literally PUMP on my head in with low frequency energy. Since rolling in the Psvanes/Genelex, the low end is now absent on "Brothers In Arms" - so imagine how insipid less bass-y recordings sound??? Moreover, the midrange is grainy and recessed.
Now, I appreciate some might cite the necessity of "burn in" - and no doubt this is quite true of capacitors (for example) that must undergo structural changes in the first tens/hundreds of hours, but is surely less relevant to tubes (which burn-out rather than burn-in, mechanically and electrically).
YMMV, of course - but my experience is that, yes, rolling tubes is audible in the HP8... and worsening is just as probable an outcome as improvement, in terms of system synergy even with putatively superior tubes. (Although at least the Psvanes actually seat firmly!)
