iBasso DX90 Bug Thread - Post Any Firmware Bugs/Issues Here
Apr 29, 2014 at 11:38 AM Post #31 of 864
Dx90 cuts the last 2 seconds of a track. Gapless on. ALAC 16/24.
Last night, my DX90 paused when it reached the last 2 seconds of the track 1 in an album. I had to manually hit the play button to get it to continue on to track 2. FLAC. Tag browsing. Gapless on.
Apr 29, 2014 at 4:27 PM Post #32 of 864
I've tried to copy stuff to the internal storage of my DX90 for the first time today. It was detected okay by my PC and I could start copying stuff.
After copying one file the copy process stalled and I had to unplug and replug the DX90 to continue copying.
Same happened again and again after copying a couple of files, to I decided to reformat the internal memory to exFAT,
Tried a full format with Windows resulted in a "failed to finish formatting" error, so I did a quick format which finished okay.
Now I suspect the internal storage could be defective. Will try with another USB cable though to confirm.
It could as well be a software issue, so I'd like to wait before sending the unit back to iBasso.
Anyone had a similar experience copying music to the internal storage?
Apr 29, 2014 at 4:36 PM Post #33 of 864
I have never tried the internal memory since it is small and reserve it for wallpaper. But, will try it later.
Apr 30, 2014 at 2:11 AM Post #34 of 864
Worked fine for me - transferred several albums in FLAC format to internal storage without any problems. Maybe try formatting to FAT32? Good luck!
Apr 30, 2014 at 3:54 AM Post #35 of 864
Thanks for the replies. I've now tested with a different cable and it's the same. Now the device even doesn't say "usb connected" any more. Even after a factory data reset.
Damn. Looks like a hardware fault.:/ Will do one last test with a different PC.
Apr 30, 2014 at 11:32 AM Post #36 of 864
I don't think the internal memory should be formatted with exfat.
Apr 30, 2014 at 12:15 PM Post #37 of 864
I now had the same problem when copying stuff to the micro sd card in the DX90, so it might be a general problem, not necessarily the storage. But still, I would need to reformat it somehow as FAT32 again.;)
May 1, 2014 at 1:40 PM Post #38 of 864
Just FYI. It wasn't a faulty unit or cable. Seems like my Windows 7 PC is the culprit. While there were no problems when using the DX50, the DX90 experienced said problems.
I've asked iBasso for support and received instructions to reflash my DX90 which - after several flash fails on Windows 7 - eventually worked using my Windows 8.1 laptop.
Also copying files to the internal storage works without any problems on Windows 8.1 now.
Thanks to iBasso for the quick support.
May 1, 2014 at 7:13 PM Post #39 of 864
Don't know if this is a feature or a bug.  In shuffle mode when pressing rewind I would expect the player to go back to the previous track but it just goes to another random track.  I am used to the Cowon players and they go back to the previous track when you hit the rewind button.
May 1, 2014 at 8:42 PM Post #40 of 864
The DX100 has always exhibited this same behavior you describe in the DX90.
May 1, 2014 at 9:37 PM Post #41 of 864
Does anyone of you hear any electric sputter noise when gapless is on or the screen turning off?
May 2, 2014 at 1:15 PM Post #42 of 864
Just to inform you all what iBasso wrote to me today:
"Hi,
Thank you for your email.
We have addressed the scan bug.  A new DX90 firmware will be releaesd around May 15th.
Also, the first version Windows USB-DAC driver will be released before May 15th.
Sincerely
iBasso Audio"
Let's wait & see...
May 3, 2014 at 9:55 AM Post #43 of 864
"Hi,
Sincerely
iBasso Audio"
Let's wait & see...
Yeah for that...can't wait.
May 4, 2014 at 5:43 AM Post #44 of 864
OK, so this morning something strange happened:
Yesterday in the evening while not using the DX90 but wanted to continue to burn it in with the burn in cable, I took out the battery and plugged the power by usb. I'm somehow paranoid overcharging.
This morning when I woke up the device was on pause, and I couldn't play a song.
The strange thing:
The device made click noises every 2/3 seconds.
Also there was a not very loud high frequency noise coming out from the device, very clear when my ear is close to the device.
I plugged out the cable, put the battery. No more clicks, but still high freq noise. Now there is no noise anymore.
Strange...
May 4, 2014 at 6:58 PM Post #45 of 864
I would leave the battery in. When it is charged the charger shuts off.
