rebbi
- Apr 11, 2016
I would advise to send in for a repair while still on warranty.
Yes, agreed. Sounds like perhaps the battery is losing its charge.
Hi All.
I just got my DX80 today and loving every inch of it. Haven't encountered any bugs (after updating to 1.4.2) but I've got two significant suggestions and one not so much - not sure if anyone from iBasso is still reading this thread but I'll post anyway.
1. There is no information anywhere on which card slot is 1 or 2 and also how the cards should be entered. Through googling and deduction I figured that both cards copper pins should be facing the slots separator (and also each other). And that slot 2 is the one further from the screen. Such information should be in the quick start guide, in the manual or somewhere on iBasso website.
2. When browsing by genre the player only displays tracks, not whole albums. When using genre browsing I'd like to be able to see a list of albums under selected genre, not per-track based list. Of course some people listen through tracks and some listen through albums. But currently people who only listen through whole albums have no use for this function.
3. The drop-down quick menu got really ugly (not sure which update - I jumped from 1.1.4 directly to 1.4.2)! I understand the change was to make it clear which function is enabled but visually it's so much worse and less elegant than the original.
I'm sorry if the above was already stated here.
Still I consider my purchase of DX80 a very fortunate one.
Hi All.
http://www.head-fi.org/t/786443/ibasso-dx80-impressions-and-reviews-and-discussion-new-fw-1-4-2-link-1st-page
Not sure what this was supposed to mean.
The microsd orientation info should be supplied to iBasso customer through official means, not in a forum thread to which a typical customer has no immediate link or knowledge.
I found it on their Facebook site as well.
https://www.facebook.com/iBassoAudio/
Hi,
Would it be normal for the DX80 battery to drain a lot faster driving a pair of full size cans in Hi Gain mode than it would driving a pair of IEM's in Low Gain mode? My friend lent me a pair of Mr. Speakers Alpha Dogs to play with. It sounds awesome with the DX80 but the battery seems to drain a lot faster.
Thanks.
Full size cans on high gain obviously use much more power than IEMs in low gain. And Alpha Dogs are planar which require even more power. So in short... yes.
I've experienced battery drain even when not using the unit. The drainage can be as much as 20% down after full charged over 24hrs. I've used the unit for about 6 months so I'm sending in for repair. Anyone experience this sort of problem after using for at least 5 months or more?
I just sent my DX80 in yesterday because of the same issue. I bought it in Dec 2015, and as of yesterday, loosing 10% charge in a matter of 3-4 hours of not turned on at all. The distributor in HK said its normal, as its like a smart phone on standby. I said to him even my smart phone on standby doesn't loose that much charge, and I insisted on for him to send it back for a check-up.
