MaxLaMenace
- Jan 13, 2016
Thanks mikeral and jamato8. I will apply all your tips and then I will report any fix for my scanning issue.
The player played via line-out, the battery is almost running out and I decided to connect it to the charger, went to settings and chose USB Charge only mode, and the volume dropped immediately
Has this card worked on other daps? Seems it could be a tagging issue. Maybe do a factory on the Dx80 and then try again with the scan. I had some files that acted weird or wouldn't scan so I used a program to check tags and it cleaned the files up, which didn't take long but most all my cards from 32gb to 200gb are fine and didn't need anything to have them work well. I have lossless, WAV and DSD.
updated 1.2.1, with several factory resets (via advanced menu & recovery mode) before & after, the backward, play & forward buttons (both solid buttons & on-screen) became sluggish. took 2-3 seconds for it to respond. factory reset the device 2 more times, the sluggishness was gone, but came back again this morning. strange !
another issue is the thump when changing tracks is louder & happens more often than 1.1.4.
edit :
gone back to 1.1.4, no more sluggishness, thump much less noticeable. regarding SQ, agree with others that 1.2.1 sounds more analytical with better separation, while 1.1.4 feels warmer & more musical. can't really say which is better for me, guess depending on recordings. anyway, will stick with 1.1.4 for now as the 1.2.1 sluggishness & thumps really bug me.
one good thing is switching FW version is pretty easy. can play around when needed.
Stay updated on iBasso at their sponsor profile on Head-Fi.
Hey, I figure it out and the problem comes from the tags of my wav files.
(ps: I used windows media player to rip those wav files).
Nevertheless those tags seem perfectly correct on jriver.
I got some weird thing happen among those bugs that was mentioned before, it's seems sometimes I pressed play/pause button then it will change the song just like I pressed next button not sure if my finger was slippery into next button or its just another bugs
I just received my dx80 today. I have a problem that the player cannot be recoginized as a card reader when connecting to my PC. USB setting is set to reader. Just nothing happened when I connected the player to my PC when the player already turned on. Tried both 1.1.4 and 1.2.1 and it is the same. The SD card can be recognized on my PC when I put it into my own SD card reader.
hmmm.. I am pretty sure the USB slot of the player is not functioning. I even cannot charge the player. Have to send it back for an exchange.
Did you try a different USB cable?
