how can m2m cable got malfunction ?
iBasso DX80 Bug Thread - Post Any Firmware Bugs/Issues Here
- Thread starter wolfen68
Paul - iBasso
Sponsor: iBasso
There could be a short. There has to be a reason the DX80 is getting hot. You also said the battery life is short?
Stay updated on iBasso at their sponsor profile on Head-Fi.
yes, maybe caused by my m2m
Paul - iBasso
Sponsor: iBasso
Yes can you try another one or do a resistance check on it? Checking the resistance from R channel to L and each channel to ground.
I don't have tools to check the resistance, but okay I will try another m2m perhaps from another manufacture free included m2m
Anyone know why the 16k and 12k doesn't work n the EQ? I move them up and down and I get nothing. Adjustment starts at 10k. I have the newest firmware, but can"t get this to work
Indeed, (I tested with 1.1.4, so can't say whether it worked before) the last two EQ bands (10k and 16k) don't work (for the plot, the last three bands (6.3k, 10k, 16k) were set to 9):
Nothing at 10 and 16 kHz.
And now the same, just with the last two bands (10k and 16k) alone:
Just as flat as with no EQ although I set 10k and 16k to 9.
sunneebear
- Jul 29, 2002
Volume drops when the EQ is turned on. I don't see any mention of this so it might be just me.
Splutje
- Nov 2, 2015
No , thats normal. The volume drops a little to create headroom for elevating certain frequency ranges. Otherwise you could get clipping when enhancing a range too much.
Really interesting is the fact that the two upper ranges arent working. Very perceptive from NatalieAnn and great verification by HifiChris. Using the presets in the EQ already gives a different sound, but this is without the two upper ranges? I wonder what the sound will be with the presets when all the ranges do work as intended.
Hmm maybe it's silicone case caused my dx80 got overheated o.O but still changing L/R balance slider made this unit dead silent ( has to press next button ) anyway is that normal if I resuming playback it will goes into random track? (in line out mode)
Please make sure the cable is not malfunctioning or try another one. The DX80 doesn't heat up when used in line out and just slightly when using the headphone output and hi resolution files.
The new FW should be out today.
will it be out today????
natalieann
- Jul 23, 2015
Will the 16 k and 12k on the EQ be fixed?
natalieann
- Jul 23, 2015
no, mine does the same thing
Just as Splutje said, a volume drop with enabled EQ is normal. It is done to generate headroom to avoid clipping when boosting some ranges too much.
FW1.2.1!!!!!!
Improvements with this firmware:
1. Line output bug fixed when the DX80 is used as a USB-DAC.
2. Enable sorting function on Now Playing.
3. Change from file name to title name on All Music view.
4. A more accurate battery indicator on low battery.
5. Improved M3U playlist import function, allows an apostrophe on file name.
6. Improved WAV ID3 support.
7. Allow custom wallpaper to be read from either SD card slot.
8. Allow the player to display Hebrew.
9. Scroll bar added to all of My Music views.
10. Improved OTG storage support.
11. Updated WAV decode engine.
R U GUYSEXCITED??
R U GUYSEXCITED??
ok. no popping sound. no crackling sound when i scroll up/down and swipe on the screen
