iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
Aug 25, 2021 at 2:28 PM Post #1,411 of 5,049
Yep. I did this through a PC as well and didn't find anything to update with. Screen shot below and nothing happens. Then tried that 'compatibility. zip' It's doing something! Probably corrupting everything now! 🤣
No, you are unzipping too far. Just unzip the first zip file you see when you download the FW and place that in the root of your DAP.
Aug 25, 2021 at 2:30 PM Post #1,412 of 5,049
This is the file you want be putting on your DAP, don't extract it any futher.
Aug 25, 2021 at 2:32 PM Post #1,413 of 5,049
Now installing the top one 👌 🤣
Aug 25, 2021 at 2:45 PM Post #1,415 of 5,049
I also confirm that is the correct one.
:p
Aug 25, 2021 at 3:16 PM Post #1,417 of 5,049
Wow! Finally got to the bottom of that one! Looks like all is operational with OTA plus Local upgrades having been done successfully. Many thanks for everyone's help. 🙏
Aug 25, 2021 at 3:59 PM Post #1,421 of 5,049
Hey Whitigir đź‘‹ That Sandisk Edge SD Card is wondrous! It's made my CD collection much more 'musical' and detailed. The sub base and soundstage is amazing and now my Depeche Mode listening is made even more detailed and 'deeper'. Thanks for the recommendation! Absolutely brilliant SD Card!
Aug 25, 2021 at 4:00 PM Post #1,423 of 5,049
UAPP shows in the “direct” the same 44,1 and 48. For example, this is how unfold Hiby R8 in UAPP:
and MAX3:
Did you ask UAPP developer about this? When using Tidal app and playing masters on 3MAX, sampling rate is displayed correctly in notification bar, like in this example where 3MAX did full MQA 16x unfolding:
Aug 25, 2021 at 4:15 PM Post #1,425 of 5,049
Can you please tell me where you bought the Sandisk Edge sd card and does it look like?
