iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
Aug 25, 2021 at 1:02 PM Post #1,396 of 5,047
Interesting. The Download section on ibasso's website does not allow me to download the new firmware.
The link that appeared on Head-Fi by Paul to the Fimware upgrade has also disappeared. How can I get the firmware now please anyone?
Aug 25, 2021 at 1:18 PM Post #1,397 of 5,047
I coldn't download the file with Google Chrome.. but with the Microsoft edge Browser no problems.. just Klick on the download link from Paul..
Aug 25, 2021 at 1:32 PM Post #1,398 of 5,047
Macbook
Chrome did not work
downloaded the file with safari
(Windows person earlier said use edge).
file is now in computer
unzip downloaded file
in the new file is the update and text file
drag and drop the update file into the micro sd card folder
Local update on max - may have to scan the card (do this update twice)
if the computer does not show your max, on pc or mac try another usb c cable as the ibasso ones can be so so for file transfer
or put the micro sd card into a card reader
To get the max to ahow up on a macbook use android file transfer app.
there is also update over wifi - but paul said we should do another local uodate with this one
remember the downloaded file has to be unzipped
- i want to do it all on my max! - if thats not working using a computer.
Good luck
Aug 25, 2021 at 1:43 PM Post #1,400 of 5,047
Mixplorer has a nice Unzip feature if people need a good File Explorer for so.
Aug 25, 2021 at 1:56 PM Post #1,402 of 5,047
Aug 25, 2021 at 1:59 PM Post #1,403 of 5,047
So I still have my Max so I figured I'd do this double update thing.. ermm, how do I get my Max to do the update if I'm already on the latest version? It doesn't view the downloaded FW update as an "update" since it's the same version as the one I did OTA.
edit: nevermind, click the three buttons on the top right then click local update and select the FW that way, got it.
Aug 25, 2021 at 2:02 PM Post #1,404 of 5,047
The double update instead of a factory reset?
Aug 25, 2021 at 2:13 PM Post #1,406 of 5,047
Didn't see anything on offer to update when I did the same as you.
Aug 25, 2021 at 2:15 PM Post #1,407 of 5,047
Just tried downloading a selection of WinRAR and WinZip packages to see if I can get this update into the Local update area. No luck whatsoever.
Aug 25, 2021 at 2:18 PM Post #1,408 of 5,047
I did it through PC, just download the file. Extract it and move the ZIP to the root of your SD card or Internal memory. Go to update and click the buttons on the top right, click local update, go to wherever you put the file (internal memory or sd) and the FW should be there. Click on it and it'll update.
Aug 25, 2021 at 2:27 PM Post #1,409 of 5,047
Yep. I did this through a PC as well and didn't find anything to update with. Screen shot below and nothing happens. Then tried that 'compatibility. zip' It's doing something! Probably corrupting everything now! 🤣
Aug 25, 2021 at 2:28 PM Post #1,410 of 5,047
Still installing...
