iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
Sep 23, 2021 at 12:53 PM Post #3,226 of 5,031
Sounds like a description of the Amp12
& congrats on a great purchase!
This is what so amazing about 3MTi.
soundstage is similar to Amp12 but deeper, larger, taller, with sharper and more vivid imagings/placements cues
sound signatures is however very balanced and neutral as amp11 MKII… hell, even more neutral
Overall clarity, airiness and separations are also another tier
Extensions on both ends are also another level
That is why 3MTi is the best of Ibasso yet!! It really is an amazing little machine
Sep 23, 2021 at 2:57 PM Post #3,228 of 5,031
Sep 23, 2021 at 3:27 PM Post #3,230 of 5,031
. In the end I did a factory reset and the watts went up. And it is now charging normally
Did you update to latest OS?
So then, the cable that is included with the DX300 that is 4.4 to 3.5...can that be used to connect line out to rca amp inputs?
I bought this little adapter to fit iBasso cable (3.5 out), and then goto the single ended line level cables.
This is Temporary until I get a custom cable made, as my tube amps also have balanced inputs...
Sep 23, 2021 at 3:39 PM Post #3,231 of 5,031
Yup, I ordered a female to female 3.5 adapter so I could use my 3.5 to RCA cable to connect to my Denon 2-channel amp (PMA-A110). It does not have balanced input but boy oh boy it has output to the Klipsch Cornwall IV. I already have a 4.4 to XLR cable for the Cayin HA-6A but I really want to hear the 3Mti on the speakers.
Sep 23, 2021 at 3:51 PM Post #3,232 of 5,031
Hello I need help. I just received my DX300 ti and the Amp part is not charging. I can listen to music when it is powered from the mains with the little red led flashing but if I unplug it no longer. the A% charge indicator is green but remains at 0%. do you have an idea ? A big thanks !
Sep 23, 2021 at 3:53 PM Post #3,233 of 5,031
Try a restart, the battery is probably trying to scale and balance itself ? Or just leave it in the charger and don’t use it for 30 minutes … see if it charges ?
Sep 23, 2021 at 3:58 PM Post #3,234 of 5,031
Thank you I tried to restart several times and do a factory reset but nothing changes it remains at 0%
Sep 23, 2021 at 4:02 PM Post #3,235 of 5,031
How long have you been charging? I would set for a few hours charging.
Sep 23, 2021 at 4:06 PM Post #3,236 of 5,031
I would immediately install latest OS.
Sep 23, 2021 at 4:07 PM Post #3,237 of 5,031
10h last night and 5h today
Sep 23, 2021 at 4:09 PM Post #3,238 of 5,031
Sep 23, 2021 at 4:10 PM Post #3,239 of 5,031
Yes I have already installed the latest firmware
Sep 23, 2021 at 4:11 PM Post #3,240 of 5,031
Turn off Ti completely and recharge with supplied charger for at least an hour.
