My 3Max connected with my iPhone Xs (iOS 14) personal hotspot. Didn’t do anything special on max side.I think I may have figured out why my 3Max is unable to connect to my iPhone 12 Pro Max running IOS 15.. Android 9 needs to be updated to enable support for WPA3 / SAE which IOS 15 uses for Hotspot connections..
Now, if only I could figure out how… can someone good with Android help?
iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
- Thread starter Paul - iBasso
Death_Block
for some reason I have no idea, I wold have thought a cube of Ti would be more expensive
DaYooper
- Oct 14, 2013
How big is that cube !!!???This one came with the LPGT-Ti
DaYooper
It's 13/16" and weighs 43 grams.
- Oct 14, 2013
Why does it look so big in the pic lolIt's 13/16" and weighs 43 grams.
DaYooper
DaYooper
DHL is saying next Monday for mine.
behemothkat
Big jitter in transmitting data process leads to packet loss. To avoid it each data packet has one byte (8 bits) used for CRC transmission. ECC if CRC check did not pass request to retransmit the same data packet. If data transmission stuck in retransmission of the same data packet for a long time data transmit process will be end with error code (this happens when your memory card fails) - so, data will not be transmitted.But typically with a digital signal the source of errors comes from timing that results in jitter due to skewed clock/data edges.
In regards to music files: no data = no sound. DAP will stop to play file. There is no any “skip” procedure for data transmission like it was for red book CDs.
meomap
Mine say just landed in LA, CA...
2 more days?
2 more days?
DaYooper
Ya, mine is in Chicago Land, but DHL is not as good as UPS.
- Oct 14, 2013
The errors is related to time domains, and it would be “clicking” as Alex mentioned and as you said...no sound..just click ?. This brought to me that the Streaming and tidal issues could relate to this ? Possibly the router or network issues before the device or playback app, or firmware….but then again, I don’t stream.Big jitter in transmitting data process leads to packet loss. To avoid it each data packet has one byte (8 bits) used for CRC transmission. ECC if CRC check did not pass request to retransmit the same data packet. If data transmission stuck in retransmission of the same data packet for a long time data transmit process will be end with error code (this happens when your memory card fails) - so, data will not be transmitted.
Mine also just landed in LA, CA.
Expected delivery is till this Wednesday...
Total: 8 (members: 1, guests: 7)
