- Oct 14, 2013
That is even more amazing right ? If Neutron does this automatically, then you can fully benefit without degradations !!!Not me
I am so excited to get Titanium unit
Dang, this is just too much trouble! Just how much difference is this going to make to the music, man? I mean, for someone who thinks Apple Lossless is a scam (can't hear no diff from Lossy!), is it going to matter? Can I just stick the files in those super Micron i300 (not CS) cards and voila! Music is served...If your files are 44.1 or 48Khz.
If it is 384, then set 2X
If it is 192, then set 4X
If it is 96, then 8X
I recommend to organize files to folders, and then play accordingly to OS setting
I am with you. I am not going to change settings for each source. I am going to do a reset to defaults, add follow source frequency and let er rip.Dang, this is just too much trouble! Just how much difference is this going to make to the music, man? I mean, for someone who thinks Apple Lossless is a scam (can't hear no diff from Lossy!), is it going to matter? Can I just stick the files in those super Micron i300 (not CS) cards and voila! Music is served...
I uploaded above my settings: frequency stays at “default”, switch on “Follow source frequency”, set OS to 16x, and I’m all the time on highest rate. For DSD playing I have enabled “Native DSD”, so, DSD plays without any conversion.You certainly can benefit from Neutron without OS , even with NOS on Dx300 still sees benefits
I need someone to verify if Neutron can perhaps automatically adjust. If it can, then 16X and leave it there will be awesome
No, there are no supported streaming services in NMP.Can one Stream Amazon HD or Tidal through Neutron on the 3MAX? If so, what's the setup?
Thanks for your info. Enjoying listening to SD Card files so not a massive issue. It's a pretty good App this Neutron. Very good sounds over and above Mango.No, there are no supported streaming services in NMP.
I think the best solution is UAPP, I stream Tidal MQA via UAPP and totally perfect.No, there are no supported streaming services in NMP.
Yes, IMO it has been the best Android Music player for a long, long time. Not the prettiest UI but sounds great.Thanks for your info. Enjoying listening to SD Card files so not a massive issue. It's a pretty good App this Neutron. Very good sounds over and above Mango.
... for someone who thinks Apple Lossless is a scam (can't hear no diff from Lossy!), is it going to matter...
Nah, I got the 3MaxTi coming, and the Apple Lossless thing is a running joke that the BT stream through my HM1000 gold sounded as good as lossless…You have a DX3 MAX and this is based on output from that?
What headphones?
Whatever the difference between the SS & Ti units, it should be mainly in the amp board, because when I checked, that the difference in conductance between SS & Ti is very close to each other:Stainless were tuned to be the best performer by Ibasso team
Unfortunately in last few weeks, there have been more arson fires in major big chip plants in Asia, so I see more shortages ahead.Or you can just wait for the next products as Ibasso keeping up with demands and business, I am sure the innovations will not just stop here. It can only get better
