- Oct 14, 2013
Yea, the line out totally bypass the Amp. To take the best of it, you should be using balanced connection, Eventhough SE is supported, it would take an extra conversion stage.No problem.
using this set up
iBasso 4.4mm to 3.5mm cable
then a female to female 3.5mm adapter
then the 3.5mm to RCA
as I understand it, going via Line out will make use of the Max dac
- and not use it solely as a digital transport.
@Whitigir can correct me here if needed
Today I tried out the Silver Litz cables from FiiO, and they are surprisingly good, excellent ergonomic, fit and build. The L plug also fit into the volume knob just fine . This cables is unbeatable for this price. It has great synergies with IER Z1R
