Has anyone noticed buzzing during quiet parts of tracks if they listen while charging?
iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
- Thread starter Paul - iBasso
- Oct 14, 2013
Very hard to spot, and it is seldom. Sometimes, just unplug and restart it and it is gone. However, listening during charge will not be as good as listening on batteries aloneHas anyone noticed buzzing during quiet parts of tracks if they listen while charging?
runningwitit
- Aug 10, 2015
Can't delete messages
I noticed little when turning on the screen after screen off.Has anyone noticed buzzing during quiet parts of tracks if they listen while charging?
The Max sounds better IMO. I sold the Kann Cube. The Cube has more power and maybe a but more detail but the sound is a bit colder. The sound stage and channel separation on the Max is stunning. The Max is by far the best DAP that I have heard.Hi,
Has anyone compare the 220 Max to Kann Cube? Your kind comment or comparison will be highly appreciated. Thank you.
I like the 4.4 output on the Max better versus the 2.5 on the KC. The KC is a good player for sure but the Max is a step up. Full android is also a bonus. I had a lot of issues getting apps loaded because the APK file I could find did not necessarily exactly match the ones OKed by AK.
Dietmar Görtz
For buyers from Europe who are interested.
https://www.head-fi.org/threads/ibasso-dx220-max-nearly-new-little-used-08-2020.939982/
Yes, unfortunately there is such a thing. Abbis 1266 MAX does not open to the full, but plays perfectly well. These are perhaps only two models of Abbis and Susvar that require twice as much power, that is, a strong stationary amplifier.
runningwitit
- Aug 10, 2015
Does this upgrade change the global sound of the player or just certain apps?Lurker firmware is a “MUST”!!!!! My mind was blown
- Oct 14, 2013
I believe it is global as I tried mango app, Neutron app, and MangoOS....but those are the only that I tried, so I can’t be sureDoes this upgrade change the global sound of the player or just certain apps?
runningwitit
- Aug 10, 2015
Delete
vr1
- Jun 1, 2009
Thank you very much for your reply. I do appreciate your advise. In my opinion I prefer A&K Kann and Kann Cube more than any other A&K daps, not that they are not good, but it is just my preference. I am considering DX 220 Max.
So, did anybody catch what the grand iBasso announcement ended up being for?
Inquiring minds want to know...
Cheers!
-HK sends
Cheers!
-HK sends
The Kann Cube is VERY good but the Max is better. AK needs to drop the 2.5. Why would you build a dap to power full sized cans and then but a super flimsy 2.5 output on it. Never made sense to me. The Max is end game for me and I have not thought about buying another high end dap since.Thank you very much for your reply. I do appreciate your advise. In my opinion I prefer A&K Kann and Kann Cube more than any other A&K daps, not that they are not good, but it is just my preference. I am considering DX 220 Max.
runningwitit
- Aug 10, 2015
Can anyone tell me how to get Tidal to play with Lurker's firmware version? The app works, but no sound is playing through the phones...
Also, the dac battery is staying at zero and it's fully charged.
- Oct 14, 2013
The batteries on the DAP is at 0% ? You may want to restart it, and see if it worksCan anyone tell me how to get Tidal to play with Lurker's firmware version? The app works, but no sound is playing through the phones...
