iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
post-14554079
Post #1,712 of 3,003
TjPhysicist
Toronto, Ontario, Canada
Another question if I may....Since this doesn't support the Google Play Store, does one have to log into their Google account upon the reception of this player?
I can't see why you would have to. In fact you don't have to logon to google account on PHONES (at least you didn't pre android P)...until you want an app that is.
post-14562522
Post #1,713 of 3,003
blackberriesandthinkpads
North America
North America
I don’t know about this, but the dx200 with newest firmware does this, and I forgot to write something about this to request it as an optional function rather than standard. Thanks for reminding
Can DX200 owner(s) confirm this? Not being able to power/charge the DAP while using it as a DAC/AMP is completely useless to me. I will mostly be using it as a USB DAC/AMP. If the DX150 cannot do this, and won't be able to via a firmware update due to hardware design, I have to consider the DX200 instead as that's a deal breaker for me.
post-14566235
Post #1,714 of 3,003
cycheang
Malaysia
Malaysia
I'm doing the burn in on my IT04 using iBasso DX150, after I left my IEM connected to DX150 for 3 hours, i felt DX150 a bit warm especially near the power button there, not sure you guys have the similar issue or it is normal ?
post-14566284
Post #1,715 of 3,003
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
Bucharest, Romania
Age
25
Website
audiophile-heaven.com
It is normal for it to be a bit warm, although I'd say it is warm on the entire surface, not especially near the power button (?)
post-14566675
Post #1,716 of 3,003
cycheang
Malaysia
Malaysia
probably you're right, because I feel it rather warm around power button and the entire surface not really take note of that because it is already cover up by the pouch
post-14574182
Post #1,717 of 3,003
cycheang
Malaysia
Malaysia
From the review I read from Web, knowing that Neutron music player is better than default Mango player. Since DX150 with original firmware did not come with Google Play Store unless flash to Lurker firmware.
If I insist to use stock firmware, possible to install Neutron Music Player ? I tried Spotify and Tidal apk and no issue found.
Neutron Music player is a paid version. Any idea get it install and it is activated in DX150.
post-14574185
Post #1,718 of 3,003
TjPhysicist
Neutron's Site actually has a way for you to legally BUY a license for the player outside of the playstore and manually download the apk from their site (many music players do this, especially in the past because not all countries have paid apps in the playstore). I used to do this with a few music players, and it works well enough.
post-14574200
Post #1,719 of 3,003
Lurker0
Moscow, Russia
Moscow, Russia
Then the license is bound to an e-mail account. So one should consider how (s)he can create an appropriate account on DX150 w/o Play Market.
post-14574204
Post #1,720 of 3,003
TjPhysicist
Oh fair point. Can you maybe download a free email app without the mod would that even work? I installed the mod first thing so i have no idea. Wonder why they didn't use an encrypted file or a passcode or smthg.
Edit: wait..OMG you're lurker.. the Lurker?! :bow:
Reactions: Layman1
post-14579120
Post #1,721 of 3,003
cycheang
Malaysia
Malaysia
The default cable come with Sennheiser HD650 is not balanced cable. Is that possible to change to 4.4mm Balanced cable for my HD650 so that I can used it in my DAP with AMP8 ?
Any recommendation ? Not prefer so expensive cable.
Thanks.
post-14579131
Post #1,722 of 3,003
ryaneagon
USA
USA
Thanks.
Here is a good thread about HD650 balanced cables.
https://www.head-fi.org/threads/affordable-balanced-cable-for-sennheiser-hd650.662135/
I use ALO audio and have had really good experience with there product for quality and service. What is too expensive, especially regrading HI-FI. Haha! Good luck.
post-14579368
Post #1,723 of 3,003
dsrk
Thanks.
I am using this one and it is good enough.
https://www.aliexpress.com/item/16-...820.html?spm=a2g0s.8937460.0.0.44142e0eDRVZga
or this if you want angled plug
https://www.aliexpress.com/item/4-4...071.html?spm=a2g0s.8937460.0.0.44142e0eDRVZga
post-14584749
Post #1,725 of 3,003
WNBC
WA
WA
I bought a used DX150 less than a month ago and since then I've installed the lurker software (fantastic) and purchased a new Amp 8 module. I'm really enjoying Amp8. Amp6 was not bad by any means. Even though the ASG2.5 doesn't have difficult-to-drive specs it does seem to do well with more power. I'm thinking about a new IEM. It's been a while since I've purchased an IEM and I kind of like the BA + dynamic driver approach so I will look at offerings from iBasso and Fiio. For ASG2.5 I do have the bass at almost the lowest setting with a very slight turn of the bass dial. I've used the DX150 as a digital transport into my Bimby which is part of a speaker rig. Great for not having to keep a laptop attached to the Bimby.
Nothing new here to report vs what has been reported other than to say I like the DX150, very cool stuff. Before this I've never been a DAP guy. I was skeptical before purchasing because I've tried a handful of low-mid tier to mid-tier DAPs and transportable DAC/amps. I usually ended up selling them off after losing interest. I think the DX150 is here to stay for a while. But, of course there is always the wonder if the DX200 would be the final solution. Well, maybe the DX200ti would be the final solution :wink:.
