crashtest33
Member of the Trade (Cable maker)
Ordered! Can't wait to hear some AK DAC loveliness after my much loved Hp-p1.
Why wouldn’t it be ? Just so as long as you are using a correct app that output digital audio over usb connection.Hello, I suppose the DX120 is DAC only for Linux/Mac/Windows and not Android ?
I’ve read somewhere it had DAC abilities. I may be wrong. I hope I will have some precisions about this.Oh, so this works as a USB dac after all? I thought it was meant to be a pure dap. Nicy.
I got all my album art working when resized the jpg's to max 950 KB or so.
Did a test with 384 kHz 24bit flac files, and this do not work either, like the 384 kHz 32bit files.
Maybe i need another conversion software?
I used foobar2000 to conver DSF files to flac.
Yes looks like you are right. The foobar2000 that i used, actually encoded in 24bit. The official flac decoder can't decode 32bit.I was doing some audio work the other day...cant quite remember - but I don't think Flac will support 32 bit and quite possibly neither will it do 384 kHz
at least not by default...
Also to mention that I never add artwork for commercial released audio above 500 kb and usually add 600 x 600 size-wize
Some players that have to process hi rez or large artwork will hiccup, cause a delay between tracks and occasionally cause a restart!
AuI Converter can do so much, but it is very expensive. I have not gotten around to it yet either.Yes looks like you are right. The foobar2000 that i used, actually encoded in 24bit. The official flac decoder can't decode 32bit.
The ffmpeg should be enable to encode, but i can't find free gui with 32bit in it. Looks like AuI ConverteR 48x44 can do this, but i will not pay 100+ $ for it.
I also tested the dBpoweramp, it has 24bit 384 and 352,8 kHz, but this will not work in DX120.
Now i will stick with wav, the 352,8 kHz 32bit wav is same size as DSD256 and is more user friendly than DSD. Wav works on DX120 and on free PC software players.
I think the DX120 has not enough ram to uncompress flac into 3GB PCM data.
Custom Cams have advised me that they can produce a Balanced cable for me with a 2.5 Balanced Output to SE 2.5 Input will this still cause the problem you mention. Please bear in mind I am not technically minded so must rely on other peoples' specialist knowledge. Thank you for your Input.Never try hooking up single ended headphones to a balanced amp. You will short together the separate grounds in the amp/amp section of your DAP.
Don't do it, period. Bad idea. I know it can be confusing, but it goes like this:Custom Cams have advised me that they can produce a Balanced cable for me with a 2.5 Balanced Output to SE 2.5 Input will this still cause the problem you mention. Please bear in mind I am not technically minded so must rely on other peoples' specialist knowledge. Thank you for your Input.
