wahdoy
Check on Ebay. There is one listed for $450.
Hi , i have some more question , does the DX100 can drive 250 Ohm's headphones ? Thanks in advance .
I tried HD600 & 800 on DX100 and the boy handled the Sennheiser twins fine. T1 on DX100 however, sounded a bit breathless. YMMV.
The T1 is 600 Ohms , i think it will past for a 250's ohms headphone , i have pull the trigger for a Beyerdynamic DT1770 Pro 250Ohms , i hope it will work fine with the DX100 . Thanks . Regards
For the HD600 HD800 which gain is set on your DX100 : low , mid or high ?
Low and medium.
I always try to listen in lowest gain possible and increase the volume if possible. Will only increase gain if volume cannot drive.
OK thank you very much , you're right , the lowest gain , the less ditortion
