nicolo
- Dec 16, 2011
Will you be using the stock short cable provided by Hifiman?
My mistake.
The correct instruction:
- turn on your DX100
- connect DX100 to PC with USB cable
- HOLD volume UP and press once RESET
- install Rockchip drivers for new device
- flash firmware with RKBatchTool
Just I checked. Everything is working fine.
The DX100 was working fine yesterday. However i had the same issue as yesterday after getting stuck on the start screen. I have reinstalled the firmware twice. However each time the disk gets formatted and i have to copy the music all over again. Is there any fix to this?
You could consider using sdcard to save u time from re copying
Which SD card would you recommend. I heard that that there are sound quality differences between various SD cards, though i may have misread that.
My DX100 decided to act up. It went into a boot loop and never gone past the "ibasso" splash screen. Went ahead and update the firmware 1.2.7 with Rockchip batch tool, however once the update was down, it cannot be turned on. Whenever plugged into the computer, it will show "green" in the batch tool. Seems like it is stuck in update-mode or something.
Did I just bricked my DX100!?!?
Any way to revive this?
Stay updated on iBasso at their sponsor profile on Head-Fi.
In November 2014 they still had them They replaced usb socket in my dx100 as well as the back plate.
