just a few questions. What's the difference between plugging ur headphone in the "Phone" jack and the "Aux In/Out" jack? Also how do you guys actually get 24bit/96sampling or higher recordings?
The Phone jack is an "output only" headphone jack. The Aux In/Out jack, as the name suggests, is an Auxiliary Input/Output jack which serves two purposes. It can accept an analog source "input" signal, or produce an analog "output" signal. It can be use, for example, to accept an analog input signal from the headphone out jack of a portable device (ie. an iPod, or in my case an HP Touchpad), in which case, the internal amp would be used to send the signal to the headphone out "Phone" jack of the D6. When feeding the D6 a "digital" signal via the rear input USB port, the Aux In/Out jack will output an unattenuated line level analog signal (directly bypassing the D6 internal amp), which can be fed into an external amp with a volume control. This is how I'm using the D6 DAC with my Trends amp. I use a 1/8" Mini to Dual Phono (RCA) Plug Y-cable to connect the two.
Hi-res, 24Bit/96KHz or higher, recordings are available for purchase (or in some cases for free) from several sources on the Internet. A number of download sites are listed in this Head-Fi wiki article -
http://www.head-fi.org/a/high-res-music-download-sites (IMO, very good use of the wiki, BTW. The Head-Fi wiki is worth exploring, if you haven't done so already - see my signature for the link).
Another point worth mentioning, is the D6 is currently limited to 24/96 playback. The D6 is a bit of an enigma for me because even though it implements two very good 24-bit, high performance 192kHz Wolfson WM8740 DACs , the D6 is ultimately limited by the Texas Instruments TAS1020B USB controller chip which, per iBasso's documentation, only supports up to 24Bit/96KHz signals. I have a hunch this is a limitation of iBasso's driver more so than the USB chipset, but again, this is just pure speculation on my part. Others in this forum may be able to provide more information on this. Regardless, if you wish to play hi-res files above 24/96 resolution, they must be downsampled to 24/96 in order to work with the D6.
