estreeter
- Jun 10, 2009
Yes, I am policing this thread, and you seem to have exceeded your quota for exclamation points. I'll let you go with a warning, this time.
I'm looking to get an amp for my ER4P/S. Does anyone have any thoughts whether the D4 could be a good combo? I'll be using it almost exclusively with my ipod classic. I like the etymotic sound so I'm not trying to alter/overshadow it, but rather to compliment it.
Ntropic said:/img/forum/go_quote.gif
Grr. This means they're probably going to drop the D2+ in price.
I mean, it's almost perfect. Swappable opamps, USB/9V, what looks to be the same case as the D2, line out, and for almost the same price as a D2.
I wonder if there's a way to combine the voltage from the USB line and the battery. I know there's a switch at the back... but hmm... 14V...
Hi Guys;
I need a little advise on the D4 Mamba. I bought it used from fellow head-fier; just received it today.
I am using the Beyer 990T 250ohms; playing APE lossless thru laptop.
I hear hiss and burst when i try to almost max the volume. Is that normal? It seems that the song sound better WITHOUT the amp from the laptop. Did i receive a faulty D4 Mamba?
Also which; does the D4 comes with 9V battery?
Anyway i bought a 9V disposable battery thinking to power it off battery.
To my surprise i saw one of the Golden fuse(whatever u call it) obstructing the battery clearance placement.
Which to say; there is no way for me to insert the battery.
The fuse seems to be bent in a way; almost going to break off.
What should i do? Please advise
There you go~
I do hear a slight hiss that goes away after turning it on, isnt this normal?
