andrew3199
- Mar 8, 2003
Is the IBasso D10 the only current Amp / DAC combo that offers all three "USB" "Coax" and "Optical" input, portable or none portable?
Originally Posted by HiFlight /img/forum/go_quote.gif Yes, this is the method for modifying a 744 or 5534 for Class A operation. One must remove the #6 pin, connect the #5 pin to the #6 solder pad, then use a 2.2k resistor to bridge #6 to #7 pin. There isn't much room on an adapter for using 1/4 or 1/8 watt resistors, so I use SMD resistors. They are so tiny that they don't interfere with mounting 2 modules onto a 2>1 adapter. I haven't yet found a good (easy) way to modify a dual-channel opamp to Class A operation. Maybe down the road when I get more hacking time. |
Originally Posted by rhw /img/forum/go_quote.gif WOW class A in the D10 (how does the AD743 classA sound in comparison to your topkit?) once more you are pushing the envelope, attacking my wallet, Ron ![]() or can the topkit be modified? |
Originally Posted by shredder /img/forum/go_quote.gif I'm playing with my new D10.... anyone know how to get the USB on a Mac to output the sound from iTunes for the D10s DACs to play for me? Or am i not doing something on the D10? |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I am expecting the Class A AD744 today or tomorrow, and wil report back on that one. . |
Originally Posted by shredder /img/forum/go_quote.gif Got it! Thanks! I take it I will need to pick up an optical connection adapter? |
Originally Posted by andrew3199 /img/forum/go_quote.gif Is the IBasso D10 the only current Amp / DAC combo that offers all three "USB" "Coax" and "Optical" input, portable or none portable? |
Originally Posted by jamato8 /img/forum/go_quote.gif You Mac is a mini optical so you will need a mini to toslink adapter or just buy a mini to toslink from Sysconcept in the length you need for a high quality optical cable. |
