windcar
- Dec 16, 2010
I am thinking it03 is already a bright iem. Won't adding a silver plated CB13 add to the treble?
CB13 is a 8 conductor hybrid, 4 pure copper and 4 pure silver wires, different from silver plated.
Same for me, bright to start with but after about 120 hrs the brightness went away and the bass tightened up. Maybe give them more time,How long have you had the it03? I have lil to no issues with treble now after "burning them in" And I'm quite sensitive to treble.
The CB13 has less sleeve so it should fit most any MMCX IEM. The CB12 has not been changed at this time but is very easy to trim if you are careful.Can you confirm @Paul - iBasso
The newer cb13 can now fit all mmcx iems?
Is this also the case with cb12 or no?
Stay updated on iBasso at their sponsor profile on Head-Fi.
The IT04 design is ready but we won't release it until the shells are exactly right. That is the only holdup.OK, on May 8, Paul said IT-04 would be:
A couple of months. That is the closest I can come to release right now.
and, two months later, on July 3, he said:
The IT04 are final. Production will start soon.
I'm officially ready now
@Paul - iBasso ?!?!?
