Ibasso 1 bit Discrete portable DAC with Resistors Array D16
- Thread starter Whitigir
The small one is the selector switch. It is also the DAC volume controller.
The big one is the analog section volume attenuator.
audionewbi
- Jan 24, 2010
I was on LP wechat group and someone shared this d16 mod layout.
- Oct 14, 2013
Nice! Some people already modding and stuffing that muchI was on LP wechat group and someone shared this d16 mod layout.![]()
bluex
- Aug 14, 2016
Could anyone here, please, compare the soundstage between iBasso D16 and RME ADI 2 DAC FS ?
I'd like to buy the D16 ( connected with my mobile phone S24 Ultra ) using it with ZMF Caldera Closed
Thank you
Thank you
audionewbi
- Jan 24, 2010
I love to know how much more the DAC section of D16 has to offer.Nice! Some people already modding and stuffing that much
Death_Block
Does it have a desktop mode? Or does it always draw off the battery? Any comparisons to the chord quest?
FooFighter
It's battery onlyDoes it have a desktop mode? Or does it always draw off the battery? Any comparisons to the chord quest?
I haven't heard Qtest but isn't it the same DAC as in Hugo2?
If yes you can search in this thread and find hints for your question
Death_Block
Ah, didn't realise they shared software.ive only just been serious about the cutest tonight. Alot to catch up onIt's battery only
bluex
- Aug 14, 2016
I just received the iBasso D16, didn't have much time to test it out
I'll be back at home, later tonight. I just put it to charge
With the 3.5 mm jack, can I use Amp high gain?
Which settings would you recommend? Amp, all the way up, and then adjusting the volume knob?
Thank you
Thank you
Nightshifter
Thank you
You can use high gain with 3,5mm single ended or 4,4mm balanced output.
I use these gain settings: DAC high, AMP high and I set the digital volume (small knob) to 100.
Then I use the analog volume (big knob) to adjust the volume. From there you can fine adjust the overall volume by going down with the digital volume (small knob) to 94 for example.
The analog volume knob only has 24 steps.
The DAC gain setting should always be set to high and the AMP gain setting depends on your gear's impedance and the chosen output.
3,5mm single ended provides 1125mW or balanced output provides 1125mW x 2.
(By long pressing the small digital volume knob you can enter the settings menu and also navigating through it)
Golyatx
im curious how you will like itI just received the iBasso D16, didn't have much time to test it out
Thank you
dpeterfy32
Banned
WARNING: INCOMPLETE CLASSIFIED SALES
which IEM will you be using the d16 with?I just received the iBasso D16, didn't have much time to test it out
Thank you
Death_Block
Undecided with one of these or a hugo2. What have people experienced owning or used both?
dpeterfy32
Banned
hugo 2 has higher resolution and is clearer, d16 has a warmer, more organic sound, d16 is smaller in size + its battery is 3-4 hours better.Undecided with one of these or a hugo2. What have people experienced owning or used both?
