i-Qube review
Dec 4, 2010 at 1:11 PM Post #61 of 62
i've been experiencing a problem with my iqube. there is this scratching noise made by the iqube volume control when i rotate it(turn up or turn down the volume). the noise is only present when the volume control is rotated, but totally silent when the volume knob is motionless. nevertheless, it's still a little annoying when i'm enjoying the music to listen to this kind of problem. is this thing normal?
Almost all pot will face that problem eventually. It is caused by either rust or dust accumulation. The easy fix is to unplug your headphone, turn the pot from one side to the other and repeat it for 3~5 minutes, then check if the problem goes away or not.
works like a charm!! thank you clieos :)
Dec 5, 2010 at 5:32 AM Post #62 of 62
Ahhh cool. Thanks. I needed that advice and it worked for mé too.
