libertine47
- Apr 10, 2010
Hi im new in this forum so be kind to me!
-forgive for my english is no so good--
I just bought an HD 650 and portable amp Little Dot MK I+ , i heard good things about the HD 650, but when i listen to then (i was listening "Ibelong to you" from Muse on my ipod classic 6th generation - the song was in wav format ), didnt surprise much i was waiting something really amazing
but nothing, i think its maybe becausa the portable amp im using or because the DAC from the ipod classic its no so good, so i need your opinion please.
I use my computer 24/7 so a friend of mine told me to buy the sound card Asus Xonar Essence STX do you think this sound car is good for the HD 650???????
maruzen
- Apr 23, 2010
i would suggest a desktop amplifier for the hd650. i cannot comment on the performance of the asus essence stx as i do not have experience with it. generally a proper desktop amplifier should bring about the best performance from your hd650. i am using just an entry level amp from little dot, the mk2, and i think it's doing a passable job. try a quick search for amps with good synergy with the hd650 here on headfi!
good luck
good luck
