Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
What prices would audiophile headphones start from?
Also what technical specifications should I look for on deciding my headphones.
Audiophile just means someone who is enthusiastic about high fidelity audio reproduction. The Koss is an audiophile headphone. It's just not as good as some more expensive models, which should be expected. You don't need to spend a lot to get great sound.
Depends how concerned you are with things like that. You can check out measurements, but you'd need to know how to interpret them, so if you're a beginner, you shouldn't worry about it. If you decide to learn about measurements in the future, you can start by looking for a neutral frequency response (that follows a compensation curve that is close to neutral for human ears with headphones; examples including the diffuse field curve and Harman curve), low distortion, and rapid impulse response (which relates to transient speed).
https://www.innerfidelity.com/headphone-measurements
https://www.innerfidelity.com/headphone-measurements-explained
