If someone was going to build a computer to run HQPlayer from, what processor and how much RAM do you think would be best?Correct. You operate it via command line through a SSH tunnel, but besides occasional updates they are mostly set-it-and-forget-it. If you were only installing HQPlayer and nothing else on this computer, you could use HQPlayer OS "instead of" Linux (technically it is still Linux... but should be far easier to set up) which would simplify a lot. If you decide to go that route, let me know and I can help with the setup but basically it should look like this:
1. Flash the HQPlayer OS image to a hard drive
2. Install the hard drive in HQPlayer dedicated computer.
3. Find the local IP address of the new computer via your router.
4. Login to the HQPlayer Embedded web interface at http://(computer's IP address):8088
5. Configure your preferred settings.
Also, where can I find and download HQPlayer OS?
