amrutmhatre90
Has anyone compared HQplayer with streamers? Like Lumin, Aurender, Holo Red, EverSolo or Pi2es?
Stock HQplayer settings vs Upsampling.
I'm trying AHM7EC5L again but with Closed-form-16M with success. It could be simply the smoothness of Closed-form-16M taking over but the combo is pleasant to my ears. Addendum, the combination deadens some tracks so this might be a good combo to try if you have some that are simply too bright to enjoy.It's definitely a weird one! Just an hour of listening so far but to my ears is pleasing. Can't exactly articulate why though. As Jussi said don't change rate and modulator at the same time, i'm used to DSD512 so some of the changes I'm hearing might be simply from upping the rate.
Thanks @GoldenOne - Would an objective comparison of the same upsampled input file via PGGB and HQP PCM upsampling (using some popular filters) make sense? If so, what value would such a comparison provide in your view?So the new DSD modulators in HQP 5 are pretty incredible.
ASDM7EC-Super 512+fs achieves nearly 300dB SNR at DSD512, it's limited in accuracy by 24 bit input, not the modulator itself. Good lord
So this post might go a little beyond the scope of this question but hopefully will be interesting for those curious about the differences.Thanks @GoldenOne - Would an objective comparison of the same upsampled input file via PGGB and HQP PCM upsampling (using some popular filters) make sense? If so, what value would such a comparison provide in your view?
Hailo.@EMINENT I'm fascinated by your adventures and would like to know a bit more about your computer.i was looking at a 7950x3d but might change to the i9 14900k. The AMD is cooler but I believe I will get better results with the i9 and Holo may since I'm stuck with windows.What us your cooler and motherboard. Also what are your overclock results.
You can get better accuracy by upsampling with PGGB then doing the DSD modulation with HQP if you want to really push the limits of what can be done.
Haeloh.For those who are interested, the combination of using PGGB to upsample files offline then using HQPlayer to further convert to SDM and upsample is being discussed here. https://audiophilestyle.com/forums/...ew-of-math-and-magic/page/74/#comment-1262021
I gave it a try on a few files and one of the unexpected outcomes is I can now hit use Sinc-L, ASDM7ECv2 @ DSD1024X48. Still can't do Sinc-Mx. @EMINENT I expect this will be of interest to you. I'm probably calculating something wrong but this is131070 taps X 1024 = 134M taps. I'm wrong, I'm sure.
Could you please plot a comparison chart for ASDM7EC-Super and ASDM7EC-Super 512+fs both playing at DSD256?So the new DSD modulators in HQP 5 are pretty incredible.
Here you go!Could you please plot a comparison chart for ASDM7EC-Super and ASDM7EC-Super 512+fs both playing at DSD256?![]()
Thank you so much! So this is for the sweep tone at 1khz. I am wondering how the ASDM7EC-Super 512+fs modulator running at DSD256 behaves when the underlying content is hires in the range from 44khz to 88 khz.Here you go!
I also included a 512 plot so it can be compared a bit more easily
That's so odd, Jussi doesn't recommend running 512+fs modulators below their specified rate, but it seems the 512+fs modulator is already superior to "normal" super at 256x rate in the audible band. Not that it matters much as in either case you'll be far below the dac analog noise floor anyway.Here you go!
