So it really doesn't work right? Once activated the sound changes but it doesn't respond to further EQing? I want to make sure I have not received a faulty unit : /
How To: Installing and Uninstalling Rockbox to the HiFiMAN HM-801, 603, 602 and 601.
- Thread starter Tronz
- Tags
- hifiman-hm-801
LarsHP
No, I haven't installed RockBox yet. Just updated to the newest firmware.
Wow, you are right. I'm assuming this is due to rockbox?
turokrocks
- Sep 23, 2011
What is the newest firmware , mine came with 0.08?
LarsHP
The one at the Head-Direct web page. Don't remember the version number. It has progress on other areas, but eq is disabled as it is.
turokrocks
- Sep 23, 2011
LINK????
lee730
- Jan 9, 2011
Ok well at least we know its not rockbox that is the cause. That makes me feel a lot better. But for some reason though I am finding the player quite listenable with no EQ enabled. Not sure why but usually I would have to EQ bass down by 3 and midbass by 1 with my FX700s. Not anymore it seems.
lee730
- Jan 9, 2011
http://www.head-direct.com/News/?act=detail&id=214
Ok what about the one for the 601. That is for the 801.
thanks, hifiman 601 is now unusable. now i have to find windows to uninstall this crap.
turokrocks
- Sep 23, 2011
One note, my 601 was connected to my TTVJ slim amp , and the 601 was over the amp, both off, I came to take the rig from my office a static discharge happened when I touched the 601 and the TTVJ turned on, not the 601.........
Do you believe it, I have no explanation....
lee730
- Jan 9, 2011
Its a bit tricky to remove the rockbox. I was able to but I had to open the device and bridge the 5 and 6 connector for a few seconds to get windows to detect the device. Then I had to install the driver for the 601. Then I had to run the image program to restore the original firmware.
Noykrub
- Nov 20, 2006
I would like to know the battery life of HM-60x with Rockbox? For my HM-602 with Rockbox just only 6 hr 30 min.
Is it normal ?
Anyone install rockbox in HM-60x. Let me know the battery life please.
Thanks
Thanks
lee730
- Jan 9, 2011
I would like to know the battery life of HM-60x with Rockbox? For my HM-602 with Rockbox just only 6 hr 30 min.Is it normal ?![]()
Thanks
It seemed a bit shortened for me as well. I ended up reverting back to stock firmware. Its a bit of a PITA doing it but it can be done. I'll just wait till rockbox matures for the Hifiman (I pray that is does as it is very much worth it).
cooperpwc
- Nov 20, 2006
Nice to see a detailed thread on this. Kudos, Tronz. It sounds a bit toooo unstable as yet but a worthy endeavour. Rockbox rocks.
- Dec 28, 2010
Thanks.
I also find the Rockbox firmware to be very awesome.
