RPGWiZaRD
- Jan 31, 2010
Yes I've tried EQing my headphones flat and I didn't find that optimal sounding for my taste and slightly boring to listen to. I do usually balance it out yes but don't make it completely flat as with a flat response I'd find bass slightly lacking vs highs being slightly too prominent and mids/vocals possibly not quite forward enough in the music how I personally for my taste find it optimal sounding. I agree about the improved detail recognition though, that's mostly why I bother with EQing for starters to take care of excess upper bass bleeding into mids or shrilly/excessive sounding highs that makes it somewhat thin/analytical/cold sounding or recessed mids that makes the music sound like it's missing "weight" etc. My preference has even changed over time from when I just got my first somewhat decent headphone until today, at first I preferred a very V-shaped frequency response as that's how my EQ settings used to be, today I can barely understand how I used to think those settings could sound nice.
That's where you are wrong, I'm not blindly tuning, after lots of EQ experience and different headphones I've tried with very different sound signatures I've now got a very good sense of how I personally want it to sound like. That's why I like Sony XB500 so much for example and would pay up to like $200 for it as it's already got that kind of sound signature that is to my liking, a somewhat slanting response curve from lows to highs where bass has the biggest emphasize and mids have a decent boost and highs are slightly veiled. However it's too exaggerated in this sound signature, bass is too dominant (especially the upper bass that bleeds over mids) and mids and highs are quite a bit veiled in comparision to the bass so I boost both mids and highs to make up for it. But highs would require significantly bigger boost than mids to make it completely flat but I still don't boost the highs more than the mids or just a bit more than that but with my EQ settings the highs are still not quite on the same level as mids are and mids aren't quite on the same amplitude as strong bass tones are but this is still how it sounds optimal to me, if I make it more flat sounding than this it'll start sounding worse to me. Some spend $1000+, others are equally satisfied having spent less than $500 if they happened to pick wisely and picked up something that is closer to their personal preference in sound.
Frankly I don't care how it was intended to sound like, I'm just looking for the greatest possible satisfaction which I get when it sounds the way I want it to sound like. Why would you "pretend" to like something else better just because some1 else says that's the way to listen? I thought we all had in common to try and get the best satisfaction out of our hobby which I personally believe is when we truly find a headphone that sounds the way you prefer it to sound like and why there's such a wide range of headphones with very different sound signatures and that itself is a good point about my way of looking at this, since we all have our slightly different taste of how it should sound like. If it wasn't like that then we'd all be using the same headphones and there wouldn't exist such a diversity of headphones as it does today.
Yes your ears will often lie until you've become experienced enough and tried several different headphones and EQing, it's definitely often the case that you wouldn't think something could sound better until you hear it. However when talking about EQing we're mostly talking tonal balance, tonal balance can improve SQ in the sense if there's too big derivations from the flat response especially in certain ranges but headphones can still sound bad even if they are balanced which is what you especially pay for in higherend headphones, the sound quality is just better regardless of their frequency response balance, in fact many expensier headphones aren't really balanced either, many expensier headphones still exaggerates the highs especially and take for example Ultrasone Pro 900 which isn't particularly expensive but still expensier than most headphones and is very unbalanced with exaggerated bass and recessed mids and exaggerated highs yet it doesn't sound very bad at all.
I disagree about the real instruments vs computer generated sounds. EQing will benefit any genre, I often even listen to pop or trance when EQing my headphones but I usually also check with other genres with real instruments but I've EQ'd for years and probably spent more time on EQing than most people around here cuz I'm a tweaker that just needs to fiddle around with all settings whether it's audio or video equipment and want the best possible result I can get. For example I spent like 2 years finetuning Sennheiser HD212 Pro with very small changes, XB500 I've kept tweaking for like 8 months etc. Doesn't really matter which genre I listen to I'm still usually able to tell how it will sound more or less to my liking (which then sounds great with the other genres too).
PS, I love arguing. So just try me, I will always find counter-arguments as this topic we're discussing is very subjective so there's no definite rule to apply here. ^^
There is a reason why more expensive gear tends to be flatter proprtionally to price. Have you tried to equalize your 'phones flat? If not, please give it a try, say, 3-4 days and then judge. I liked the music I had on my headphones and speakers but after applying some equalization I like it even more. Why? Because I get more detail, sounds are more accurate to each other, better soundstaging aswell. After seeing what was lost in the colouration I now enjoy my music much more, sometimes I turn EQ off and get a feeling "Heck, how deaf was I to enjoy music this way, bottom is boomy and highs are screaming, I loose sooo much of the music itself".
You prefer to hear music the way you like but what about hearing it the way it was intented to, how can that be overrated? Nothing really personal but your method has a weakness that disqualfies it from the very begining- it has no reference sound you could tune to. You are blind in your tuning since what may seem to you desirable at first is usually just adding more colouration. That is why it is so important to first get rid of biggest overexaggerations and only later optionally apply taste correction. I myself did this on my 'phones: I first adjusted the reponse to as it should be according to sinegen test and after listening to music changed it slightly.
Believe me as I went through this myself, your ears as well as mine and many other fokls' lie. You never really know what is bad untill you hear it right, which is why giving more or less flat equalization a try is so important.
PS. All the above mentioned arguments apply generally to music with real instruments. If your preference is towards techno/trance/house or alike then yes, you don't really gain much if anything.
