Sounds like a lot of you are being hypocritical. Would you put up with this sort of track recored from other products? Your car, stove, refrigerator, or would you return to the same dentist is your fillings continued to fall out.
Can't speak for everyone but I do feel a little victimized, at the same time absolutely love the sound of the LCD3s. Probably will stay with the LCD3, if only because they are tough to unload. And no it is probably not a 50% failure rate but it is unacceptably high.
I am not sure if feeling victimized is the right word for me ... though I do feel like I have been living in a Stephen King horror novel (well the audiophile version of a horror novel).
I agree, the 50% failure rate figure seems too high, but no one apart from Audeze really knows.
As for me ... I am out of the game, have got rid of my LCD-3 ... while I am a strong fan of Audeze sound quality and comfort ,they are outstanding , a true reference HeadPhone ...
though as far as the LCD3 goes the 5th driver failure was just too much for me.
The straw that broke the camels back, so to speak.
I have gone for a different model Audeze, so I will probably not post much (if ever at all) again in this thread, else it will be like scratching an open wound.
Before I finish what will likely be my very last post in this thread ... one thing I would like to see ...
I was going to make a suggestion that Audeze be more proactive ... not just reactive.
Never have Audeze contacted me after a driver failure to ask things like ;
1) What amp do you use ?
2) What is the wattage ?
3) Do you travel much ?
4) Any after market cables ?
5) do you use a speaker amp ?
6) do you use it plugged in all the time ?
7) do you use it ... repeatively unhooking from your amp ?
8) What type of climate (heat, cold, humidity) do you use your LCD ?
Probably could brain storm some better questions ... either Audeze or the very good community here on HeadFi could do that... but I hope you get my drift ... there just seems to be zero follow up on trying to work out what the pattern is that cause the fault ... that is, is it some behaviour in the persons use ? unless they already know it is a manufacturing issue ... and whatever the user does, does not matter. Anyway, some sort of questionnaire may lead to better insight and clarity as to the actual cause. Maybe someone else has a better idea ... why not be positive and turn this thread into something which can help us and Audeze ?
Just my thoughts. I have tried to keep my thoughts balanced & fair all thru this thread (for example, "A true reference headphone" and such when mentioning sound quality, even while complaining of the LCD3 driver reliability).
Some may see my choice to stick with Audeze as unusual, though I am not ready to throw the baby out with the bathwater (had a LCD-2 previously which was faultless).
I am a very strong fan of the brand ... it is this particular model (LCD-3) that I needed to get away from. I wish the best to everyone, for my own good I will probably unsubscribe from this thread very soon.
