gpalmer
We are the weird ones.
- Apr 27, 2002
A couple days maybe with the Etys...
Originally Posted by kwitel I was thinking about getting the "plug" (koss) just to see if i could get used to them and then go for a better IEM. Are they really that bad? They can be had for about $10 on Ebay... Any recommendations for earbuds?? Thanx guys. |
Originally Posted by loopsider I don't think that is true...inverse square law? Distance makes a huge difference! 140 db SPL at 30 ft loses intensity over those 30 ft. 1/8th'' pretty much retains 100% intensity. Lets do the math (please correct me if I am wrong, because I most likely am...I have percieved from articles that the dB decrease is a linear function while the distance is exponential): 1/8''=140 db (which is, by the way, EXTREMELY loud) 1/4'' = 134 db 1/2'' = 128 db and so forth, until we achieve 30 ft... ------------------ 21 1/3 ' = 74 32 ' = 71 db? This is possibly correct, please say if I am not. Whatever the case, it stands that sound reduces intensity through distance. |
Originally Posted by kwitel Ive had the Senn mx500 and my cell phone has more bass... |
Originally Posted by kramer5150 e2c... at first it wasn't bad. Used them for ~9 months with no problems. Lately they are starting to tickle the little hairs in my ears and its ichy and irritating. Especially when I walk / move. I can lie in bed and sleep with them all night with no problems though. Its the movement and vibration that tickles my ear hairs. Garrett |
Originally Posted by Jasper994 Are you using your MX500's with foamies or without? Without foamies, they are indeed NOT bassy. With a pair of Radioshack foamies the bass is much improved, even over the stock foam. If you are using Radioshack foam and you still find the MX500 to be lacking in the bass department, then I think the only IEM that may even come close to having enough bass to suit you while still providing quality would be the Super.Fi 5 EB. |
