SP Wild
- Dec 29, 2009
Beer....one too many.
Sonic properties of cables are considered to be below the hearing treshold for a good reason. New methods or complex signals can't disprove numerous DBTs.
"Science hasn't figured it out yet, but I have" is a real classic.
Jazz - The point is not that the toaster requires heat, the point is that it requires a cable capable of supply the required current demand, a simple electrical connection.
Do you think your headphones are that different? You mention a special signal shape, but it is just an electrical connection between two components.
You know that negative DBT results prove nothing, so there's nothing to be disproved.
Are you serious? That's enough for me. No use banging my head against the wall.
You know that negative DBT results prove nothing, so there's nothing to be disproved. What would you say if the measured deviations are clearly above the established hearing thresholds? Would you still reject the new methods and their results? No interest at all?
About the MLS stuff:
These measurements are a research project and forum members posted a couple of concerns / problems with the measurements they published.
loosely translated from the stereoplay forum,
a post by Dalibor Beric, editorial staff:
The measured Van Den Hul-cable has very low resistance (which results in a very high damping factor). This exceeded the measuring accuracy and we got the wrong numbers. Therefore the measurement result clearly is invalid. All we can do is apologize - which we hereby do and also will in the magazine.
I also want to emphasize that that these measurements are a research project and therefore: a) are not part of the rating, b) are not comparable to our standard measurements. bla bla, our standard measurements however are valid, bla bla, don't jump to conclusions, bla bla, it can take quite a few month for measurement methods to become "water-proof" ...
So what can we learn from this? Don't jump to conclusions. Don't post vague stuff like "somebody did some new measurement that showed something". et cetera.
Oh and a forum member which seems to know what he's talking about explains that their method is severely flawed and is quite upset:
We've clearly pointed out that using this method to detect nonlinear distortions, as a matter of principle, is inapplicable. MLS requires linearity of the system under consideration. How you can hit on an idea like using this method for detecting nonlinear behavior is still an unexplained secret of stereoplay.
A series of negative DBTs prove that there is no difference between products. If a new medicine is found to have no clear benefits over a placebo after DBTs, it will not be passed for use as a medicine. The same should be true for cables. Unless the cable passes DBTs, the manufacturer should only be able to sell it based on quality of construction and style, not claimed 'sound benefits'.
Now it's you who's jumping to shaky conclusions: «...a forum member which seems to know what he's talking about...»!
Why? What he wrote is true and I wrote he seems to know, not that he knows everything.
Are you trying to confuse me or to distract attention?
