Roland P
In this case though, their woo woo fusebox has two spaces for fuses. One is the fuse and the other is for a jumper. I'm wondering why you would need to have a jumper in addition to the fuse. Couldn't they just hard wire that in? Is there a reason you'd want to run the fuse without the jumper?
What I read here (another black magic audio company...) http://www.kempelektroniks.nl/Files...ic_fuse_cartridge_en_hifituning_fuse__eng.pdf is:
In the Netherlands, it is not obliged to have another fuse in the Neutral-wire, so we put a durable silver coated massive copper rod in the right cartridge slot.
Also, I think it's required that both 0 and phase can be disconnected, I mean, current will flow when you connect 0 to something with a higher or lower voltage... (I've learned about this stuff, but it never had my interest lol).
