Originally Posted by Podster /img/forum/go_quote.gif
I'm glad you brought this up Milkpowder as I'm going to do some hiss testing on both my portable tonight. As far as hiss from mini to mini is a no brainer (you are amping an amped signal and the old addage trash in trash out applies.) When it comes to amping an amped signal I'm 4 sure in the camp of an external amp is of no real SQ value but it's a whole different story on the LOD out
Promise to report my findings tomorrow, I'm now curious if the hiss Oci hears in Rays amps are coming from the amp or the source material being fed to the amp
Of course if any of you are sitting there with your amp just put some IEM's on it without source in crank it and tell us what you hear
Just turn on my Predator with my UE10 connected, I find the followings:
1 Input switch to Input or line in, LO gain, Super cotton dock plug into input, no noise from low to max volume.
2 Input switch to Input or line in, High gain, Super cotton dock plug into input, moderate static noise from low to max volume.
3 Input switch to Input or line in, High gain, Super cotton dock removed, some static noise from low to max volume.
4. Input switch to Input or line in, Mid gain, Super cotton dock removed, some static noise from low to max volume.
5 Input switch to USB or DAC, LO gain, Super cotton dock plug into input, no noise from low to max volume.
6 Input switch to USB or DAC, Mid and High gain, Super cotton dock plug into input, moderate noise from low to max volume.
7 Input switch to USB or DAC, Mid and High gain, Super cotton dock removed from input, some noise from low to max volume.
