Woosh
- May 31, 2006
alright so whats the best way to punch a hole in the soft spongy ear plugs?
Originally Posted by jSatch This thread is a follow-up from another thread “Make Your Own Shure and UM2 Foamies!” started by noorudeenshakur. Because the original thread had branched out well beyond Shure and UM2 foamies, there may be many Head-Fi’ers that have missed this interesting DIY project. |
Originally Posted by Woosh alright so whats the best way to punch a hole in the soft spongy ear plugs? |
Originally Posted by afobisme hehe i did mine... with just a hot nail/tube from original foamies. it doesn't look that great, but im happy (sound is just as good). |
Originally Posted by Woosh oh yea i was wondering is it neccessary to have hard plastic tubing in the middle of the ear piece? im gona mod my cx300s with customs tips and the original silicon tips only extend about 3mm out of the driver, however these are fairly wide in diameter (5mm) so is it alright if i just cut the tips of a urethane earplug and drill a hole in the middle? |
Originally Posted by noorudeenshakur I agree the other thread went WAY off topic. Great post my friend! http://www6.head-fi.org/forums/showthread.php?t=142983 for reference heres the original thread again. |
Originally Posted by jSatch Sound is all that matters. Well, unless, of course, you impale yourself with the hot nail. Thanks for the feedback, and the pics, but be careful. PS- Which earplug did you use? |
Originally Posted by afobisme bump, i found a better way to do this. all you need is a needle, or even a toothpick. all you do is poke a small hole through the foam, put something in the hole so it expands a bit, then eventually fit a chopstick in the gap... leave it there for a little bit, then take it out and insert the tube... then it just expands back and all is secure. now i need to find a superglue with a small tube so i can glue the inside slightly without having any of it touching the outside foam. |
Originally Posted by afobisme ........... i can take a picture and illustrate how i do it, it's pretty simple actually (i can make a pair in under 2 minutes, although it's not the most beautiful thing in the world). .............. |
Originally Posted by bigDee Wow jsnatch that really sucks that you said to get 1/4" OD. I dunno what you were thinking but this is WAY too big Ah well. I'll see if petsmart has what I want. |
