bashot
- Jul 26, 2005
Apologies if this has been said elsewhere, but Im too lazy to search. Regarding heat-shrink tubing - don't use 1/8" because its slightly too large and you can't accurately shrink it down. Buy 1/4" thin-walled 2:1 heat-shrink (not double-walled, 4:1, or adhesive heat-shrink). Cut pieces to the appropriate length (or just slightly longer) and drop them in boiling water. After about 5 seconds of boiling the tubes shrink maximally in a nicely uniform manner. Fish them out delicately since they are still pliable until they cool. They shrink to just less than 1/8" I.D. and fit snugly on Shure E4 nozzles (likely similar to rest other nozzles). You'll also have a rounded edge on the ends since the sharp lines produced by cutting are shrunk down.
