@Firedrops This is how i came out with my tubing.
Base on the numbers, this is what i came out.
What went wrong is that I uses too many tubes. And due to human errors, the whole setup end up longer than what I planned about 2-3mm. And since there are so many parts, its hard for me to glue everything together without risking it falling apart during assembling and troubleshooting.
So I thought "What if i use a longer 2mm ID tube and overlap/wrap/cover/protect the whole setup?" (Give the hard work to the most lazy human on earth to do, and he will make it simplest for you.)
And this is the new tubing.
After all the calculation, I started making them.
And this is how it look like after its finished, I did not include the damper so that everyone can see clearly. You can see my 2.0mm ID is longer than usual, because WHY NOT? The longer 2mm ID is to help with friction so that they don't fall apart. This whole thing can hold themselves together without any glue, very good for prototyping.
As
@dhruvmeena96 mentioned, my 3.00mm ID tube is actually my earphone nozzle.
These it how it look like after putting together.
