Especially since they are probably buying in 100,000 piece lots.
Home-Made IEMs
- Thread starter Bilavideo
shdh
- Dec 13, 2016
Found a knock off of 64 Audio's APEX module for sale on Taobao: https://world.taobao.com/item/613205571532.htm
tedbender84
Thank you for correcting me, I was pretty sure that CI is CLit is a CI(i for intelligent) and not CL
38D1XJ is the best subwoofer and also make implementing subwoofer very easy
use a 37 or a 33 as a woofer or midband pass
Once I have 38AJ007 on hand is it possible to use it as woofer to compliment 38D1X?
musmecca
Agree with all your thoughts on the CI build, though I have not heard the Fibae 4 yet. It uses the SR and all my attempts to incorporate that driver into a build have fallen short so far. It does show promise, but I am not as smart as Piotrus!Its advanced level for sure
It needs a shell where you can put dual CI
The best part about that build is that even though its standard V shape
The Subbass CI actually helps in whole detail and subbass retention
And I feel its better than FIBAE 4 (@piotrus-g ...).. But thats my take and take it as a grain of salt
Dhruv, I am looking for a very "harmon curve" build, v shaped with more accentuated bass (ie2017...see pic). Not concerned with coloration, as I have plenty of "neutral" and "flat" IEM's on the shelf. I'll be using this for EDM, Metal, Hard Rock.....no strings or classical...Got a build for me? I know you have tried and heard a million, so though I would ask...
Farquarl
- Jun 20, 2016
The Harman Curve is the closest thing we have to neutral/flat today.Agree with all your thoughts on the CI build, though I have not heard the Fibae 4 yet. It uses the SR and all my attempts to incorporate that driver into a build have fallen short so far. It does show promise, but I am not as smart as Piotrus!
https://www.headphonesty.com/2020/04/harman-target-curves-part-1/
shdh
- Dec 13, 2016
I used a razor to remove the spout from an SWFK and then also used the razor to split the two halves of the SWFK into two WBFK’s.
I’m planning on using a razor to etch lines into the roof and wear away at the etched lines of the WBFK so I can try making my own makeshift TIA.
musmecca
So I am clear on what you are implying, you are saying these curves are flat/neutral? My apologies in advance if I have angered the Harmon gods, but those don't look flat to me. I am not attempting to go down a rabbit hole, I'm simply looking for a bass heavy build that works. Would love your thoughts if you (or anyone else) happen to have one....The Harman Curve is the closest thing we have to neutral/flat today.
dhruvmeena96
Tell me the drivers you wanna useAgree with all your thoughts on the CI build, though I have not heard the Fibae 4 yet. It uses the SR and all my attempts to incorporate that driver into a build have fallen short so far. It does show promise, but I am not as smart as Piotrus!
Harman is not neutralSo I am clear on what you are implying, you are saying these curves are flat/neutral? My apologies in advance if I have angered the Harmon gods, but those don't look flat to me. I am not attempting to go down a rabbit hole, I'm simply looking for a bass heavy build that works. Would love your thoughts if you (or anyone else) happen to have one....
First of all, even diffuse feild in iem is also wrong(kind of)
The diffuse feild speaker measurement is done in an anechoic chamber
But mostly studio people listen in a well damped room which is still no where near a anechoic chamber. This room starts to add room Gain below 300Hz
The bass shelf Harman decided was the bass most of the people like.
Harman is technically a diffuse feild + bass shelf + upper midrange tuning with the help of people sample
A true Neutral is what I think is Ety ER4 + bass driver to do a bass shelf rise from 150Hz
Because to mantain neutrality, you need 100Hz to 1kHz flat or relatively flat
But in iem, due to small speaker I feel some very fine midbass is lost if I try boosting from 100Hz.
150Hz is super neutral point for boost(what I have experienced)
Now the bass amount is subjective and also objective
What is the bass demand
My bass neutral won't be other bass neutral
But to keep it safe and easy
Neutral is more like 5dB to 6dB rise, 10dB is more of a subwoofer Or harmanish region
12dB is Fun
Above it is mehh
Farquarl
- Jun 20, 2016
I was being provocative on purpose you have not angered anyone A truly "flat" response curve would not be neutral if you put it in your ear. The natural resonances which appear in your concha and ear canal can´t take effect if your ear is occluded.So I am clear on what you are implying, you are saying these curves are flat/neutral? My apologies in advance if I have angered the Harmon gods, but those don't look flat to me. I am not attempting to go down a rabbit hole, I'm simply looking for a bass heavy build that works. Would love your thoughts if you (or anyone else) happen to have one....
I pretty much agree the diffused field curve with an enhanced bass which rises from 200-100hz is the most neutral for the middled summ of listeners. This curve will look kinda like Harman curve however there are quite a few problems with targed curves like dhruv said. It is really coarse... Look at what the range is of those treble and bass adjustmends.Tell me the drivers you wanna use
12dB is Fun
Above it is mehh
For the young ear for example, which is hears higher frequencys better, more bass is preffered. For older Folks that might not be true.
Here is maybe a better scaled graph of the harman curve.
stephensynanta16
Member of the Trade: 7th Acoustics
bro, cut it directy on the middle of the roof, dont tamper with the etched line on the side of the roof. Its what hold the whole thing together. And do it carefuly, diafragm is less than half mm from the roof surface.I used a razor to remove the spout from an SWFK and then also used the razor to split the two halves of the SWFK into two WBFK’s.
Did a mistake before, accidentally snagged my tweezer into that side line, the whole BA came undone.
dhruvmeena96
there is a 2019 oneI was being provocative on purpose you have not angered anyone A truly "flat" response curve would not be neutral if you put it in your ear. The natural resonances which appear in your concha and ear canal can´t take effect if your ear is occluded.
https://banbeu.com/graph/tool/
check it here
musmecca
Dhruv, I currenly have on hand twfk, Ed 30761 and 29689, Gv32830, Sr6438, CI22955, Fed30048, Rab32257, Hodvtec 31618, WBFK 30019, and only the sonion 33aj007...used up my other sonion products including my 3800's. I look forward to your thoughts...sounds like the 12BD fun version is what I'm after...I do have plenty of room in my shells and am pretty good at soldering.Tell me the drivers you wanna use
12dB is Fun
Above it is mehh
Which flavor of TWFK? There are a few. That's quite a pile of drivers you've got there. I think I have you beat, but I'm not looking for recipes.
shdh
- Dec 13, 2016
Yup, not going to use the seam on the side of the driver. Instead I'll etch onto the lid and attempt to create my own seam that I can continue to work at until I can pull the lid off.bro, cut it directy on the middle of the roof, dont tamper with the etched line on the side of the roof. Its what hold the whole thing together. And do it carefuly, diafragm is less than half mm from the roof surface.
musmecca
I have the TWFK30017...Digikey/mouser make it so easy with their pricepoint discounts! LOL Any bassheavy builds that you liked, throw them my way!Which flavor of TWFK? There are a few. That's quite a pile of drivers you've got there. I think I have you beat, but I'm not looking for recipes.
Total: 17 (members: 0, guests: 17)
