shdh
- Dec 13, 2016
I 3D printed a part I designed that accepts a 1.5mm outer diameter, 1mm inner diameter tube, then I used blue tack to seal the part to the coupler. I am using the Vibro Labs Veritas, so it’s not an actual IEC711 coupler, but it’s good enough for initial measurements. I should buy a proper coupler off Taobao or AliExpress though.This is great! How did you manage to seal the tube with the coupler? Mind sharing?![]()
Is this an adequate coupler? Or should I be looking for a different one?
