Thank you very much man! I have a pair of 32063 RABs only, and don't think 3 tubes can be fit in my ears unfortunately. I would like it tho. Will try to fiddle with some test shells to be sure.
May I ask what is the improvement of your last version frome the one on the picture?
For sound signature I love my pair of akg k240 for example, somewhat warm-neutral, love details, not a bass-head. Is this MASM7 is the right way to go?
The improvement: with 3 bore, u can tune MASM7 freely to your taste. And the most important was, since we had less damping on the TWFK, it fixes the last-gen MASM7 weakness: lack of treble
MASM7 tri-bore was quite flexible to tune, if u prefer less bass, u can try:
DTEC: white @ 10mm, brown @20mm
it'll lessen the bass, and because now dtec also singing on the mid, u'll get extra resolution on the mid because now it has 5 driver singing on the mid (2xFK, 2xDTEC, RAB). But it'll shift the vocal to the warm-ish.
My recomendation: buy extra damper with another color, you can shift the whole tonality by playing with damper on the DTEC & TWFK.
Less damping on DTEC will shift tonality to warm, less bass, but will get more resolution on mid.
More damping on DTEC do the opposite,
U can go undamped on the TWFK if u really love those treble
My current masm7 configuration:
RAB 32033(i stick a cloth on the vent to make it sounds like a 32257)
10ohm before BZ6 zobel
TWFK: white @ 10mm
DTEC: orange @ 20mm
Try white + green/red on the DTEC, mine which use orange, lose a little bit of those gorgeous mid resolution.
My head was still not able to cope with the bass, having a bass which doesnt affect/bleed into mid in any way, feels weird (too HIFI, LOL)
